Question about TruTech TT320
NO PICTURE ON SCREEN....SIGNAL MAYBE
I turned the dvd player on and everything was working fine. then i accidently pushed the pscan/normal button. and lost signal. i don't know how to get it back. i need to get it fixed in like 2 hours cause it's my ex's and she's mad as all can be. please help!
  • marne18 Jul 10, 2008
    i pushed that button again and nothing. i almost got it by doing the 6 sec thing. but my screen still says No Sync. Signal. any other suggestions?
(Found via google on another forum, this worked for me, while the 6-second stop button did not):
you must restore factory defaults using the COMPOSITE output OR with S-VIDEO, use the following (blind):
Power On
Open Tray
SET-UP
LEFT
ENTER
UP
ENTER
ENTER
the tray will close and S-VIDEO will return
Posted on Aug 02, 2008
    Genius:
  • TruTech Master
  • 1,550 Answers
Push the button pscan/normal that deactivates the function,or do this turn on the dvd get out the disc live the tray open and then push the stop button for 6 sec.Good luck.
Posted on Jul 10, 2008
My memorex combo dvd & vhs player is not working right. can you help me? the vhs player works fine, but the dvd player display's a split screen on the tv with a large yellow box with the word PSCAN....
PSCAN is a short form for Progressive Scan - a line scanning format used for High Definition TV. Standard TVs use Interlaced scanning. On your DVD/VHS player, the VHS is an analogue signal recorded in interlaced mode so is fine for a standard TV. The DVD is a digital signal and cazn be processed for progressive scan output in order to produce a better picture on a High definition TV (or a TV capable of handling progressive scan). If you cannot to your TV via the HD outputs then you should be able to set the DVD player to output interlaced instead of progressive scan.
Mar 05, 2011 | Memorex MVD4540 DVD Player/VCR
How can I get ride of the pscan split screen view on my memerex vcr-dvd player without the remote control and no manual
I'm not sure what is model number of your VCR-DVD combo so providing you general info to turn off pscan.
Put disc in player, press play to have distorted picture then press stop button to stop playback.
Now press and hold Stop button on unit for 6 seconds that will turn off pscan mode.
Or let me know exact model number of your player to find out solution.
Thanks.
May 28, 2010 | Memorex MVD-2045 DVD Player
I have a model DV-28881 I accidently pushed the pscan/normal button on the remote, and now it will not play or go back to DIGIX. Instead it goes to Video 1. How can I fix the problem?
Simple I only paid $32.00 for the unit and was not about to pay to have someone tell me to push a button and fix it. I did not figurre it out, so I just threw it away and will buy a new one. BUT NOT a Digix.
Dec 13, 2009 | Televison & Video
Black and white??
Press again that button
Jul 09, 2009 | TruTech DV288B3 DVD Player
Split screen with pscan warning on
I had the exact same problem and I consulted the manual. All you have to do is turn the PSCAN swtich off. It is located on the back of the dvd player. Then turn the dvd player back on and your problem should be fixed.
Jun 07, 2008 | Memorex MVD2022 DVD Player
I cant get my dvd to run without the pscan split screen coming help.... follwed directions in manual it didnt work HELP memorex dvd player model#mvd2022
had the split screen with pscan triangle looked for the button on the back, no button but on the remote was a button named V.MODE pressed it and everything back to normal thanks for the help
May 16, 2008 | Memorex MVD2022 DVD Player
Pushed the pscan button by mistake
Should be as easy as pushing the pscan button again. You might need to unplug the dvd player for a while till it goes back to factory. The P is for progressive scan and your tv must not support P. Once you get it turned off it will work again. There also might be a button on the remote to turn it off.
Feb 06, 2008 | Starlite NP625 DVD Player
Magnavox DVD/VCR player stuck in progressive scan mode
Right, mine was stuck for a couple of weeks and i tried lots of different things. What worked for me was plugging it out and in again. Press the power switch and then just before the tv switches from normal mode to dvd recorder press the eject button. However, I pressed it a few time so not exactly sure which one worked.
The burned DVD is now in a thousand pieces at the bottom of my bin!
Good Luck!
Oct 20, 2007 | Emerson EWD2202 DVD Player/VCR
DVD has no color
Check your remote for a button that says, Progressive Scan, or PSCAN. Push it and then play your movie. Should work. Worked for ours. Good luck.
Sep 15, 2007 | Televison & Video
Turn off progressive scan mode
If you set progressive scant On by accident,you must reset the unit. Remove any disc from the unit and close the disc tray. See that "disc" is displayed on the display window. Now press STOP and hold it for more than 5 seconds before releasing it. The video output will be restored to the standard setting and picture will once again be visible on a conventional analog TV or monitor.
Sep 05, 2006 | Zenith XBV443 DVD Player/VCR
TruTech TT320 Logo
132 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
