Question about Dryers
Maytag Dryer We have an electric, fron-load Maytag dryer that is 2 years old. When we used it last night it was emitting a very hot, burning smell. I opened the door to stop it and a bit a smoke came out of the door. It has been running hot lately and doesn't cool down, the clothes always come out very hot when it's finished. What could be causing this?
  • 481 Answers
The high limit switch may be malfunctioning. i would have it looked at by a professional. this could be a fire hazard.
Posted on Jul 10, 2008
My amana dryer smells like something's burning
You will need to open the dryer ans clean the internal duct work.
May 22, 2012 | Amana NED7200TW Electric Dryer
Smelled electrical burning last night and unplugged my GE profile dryer and one of the prongs(3 prong type) was burned
This usually indicates a loose connection. Check the wire connection inside the outlet and the connections on the back of the dryer. Make sure the nuts are not cross threaded, this commonly happens with the fine thread. When a loose connection happens the electricity will generate heat trying to make the connection, the cause of many home fires every year.
Oct 15, 2010 | GE Profile Harmony DPGT750EC Electric...
My 5 year old Whirlpool dryer just didn't start one day.Instead of dealing with repair,we got a used 4 year old Maytag dryer.It dried the first load,then when I pushed the start button it made a weird...
It is the motor winding shorted out which caused the smell. If you still have your old dryer the safty thermal located on the exhaust housing is blown. White plastic with 2 wires going to it. Very inexpensive repair. Hope this helps.
Feb 13, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My Simpson Sirocco 3500 clothes dryer emits burning smell!
1)check for something stuck between drum and dryer housing 2)check for stuck vent flapper at exhaust opening outside 3) check dryer lint screen
Nov 05, 2009 | Dryers
Dryer will not start
IT SOUNDS AS THOUGH YOUR MOTOR HAS LOCKED UP AND FAILED. THE BURNING SMELL IS THE VARNISH FROM THE WINDINGS OF THE MOTOR. REPLACE THE MOTOR. THEY CAN BE HAD FOR AROUND EIGHTY DOLLARS
Jan 27, 2009 | Whirlpool LER5636P Electric Dryer
Duet Gas Dryer- burning smell
first is first ,,, disconnect dryer from plug,, now open bottom panel 2 screws ,, now go and get youre vaccum,shop vac, anything ,, reason for burning smell ,, usually catching on fire ,, we recommend do this 1 as year,,, after cleaning , put about 2-3 fabric sheets inside dryer and let it runn for about 30 minutes to remive smoke from drum,,, thank you
Dec 29, 2008 | Dryers
Maytag neptune front load dryer
Your exhaust vent is probably plugged. Remove venting from the dryer and check for lint build-up, and also check the vent flap on the outside of your house for clogs. If venting appears to be clear, you might have a bad blower (although you should notice an abnormal noise with that).
Jun 20, 2008 | Maytag MDE9700AYM Electric Dryer
Dryer
Open dryer's cover and look that the belt is OK and in place (over the tub and the motor) Try to find out from where the burning smell comes from. Does the motor spin ? Let me know with your results and I will do my best to assist you with your problem.
Aug 02, 2007 | Amana DLE330RAW Electric Dryer
Gas smell from dryer
your igniter needs to be replaced.
Jan 26, 2007 | Kenmore 74842 Gas Dryer
Dryers Logo
125 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
