You can return the phone to its factory settings and remove all of the programmes and data you have added by resetting the system. Performing a soft reset If your phone responds slowly, stops responding, or freezes, try a soft reset. A soft reset causes the phone to restart and re-adjust memory allocation. Unsaved data in open windows may be lost. To perform a soft reset: Press the RESET key inside the hole on the right of the phone with your stylus pen. Performing a hard reset To perform a hard reset: Follow the soft reset procedure on the previous section while also sliding the Power key down and holding. Resetting the phone To reset the phone's system: From the Start menu, tap Settings ? System tab ? Clear Memory ? Clear Memory. Write "yes" in the input field and tap Yes. After about 5 seconds, the phone reboots and then begins alignment process. RESET key inside the hole WARNING! Resetting will delete all your programmes and
data you have added.
