Question about Onkyo TX-SR875 Receiver
Onkyo 875 Audyssey will not detect
Ok guys, this is Onkyo # 2 for me, both have the same problem.
when i go to audyssey set up, it detects L front, center, but not the R front. swapped speaker positions, verified polarity but still not detecting R front.
Also get an error message on the R back.
this is my second rec from the big C with the exact same problem.
Is there a known software issue with Audyssey?
stumped.
No solution from me but just to say i am having exactly the same problem - did you get anywhere with yours?
Posted on Dec 09, 2009
I have an Onkyo TX-NR609 receiver that I'm very pleased with. I just upgraded my speakers to a set of Klipsche quintets with 400watt, 12" subwoofer. I don't want the text book answer o
You will need to go through the speaker setup menu and select the configuration and crossover frequency for the speakers. If you set to full range, your sub will not be engaged. Subs are only good at low frequencies, so use the lowest frequency for the crossover. (40-80Hz) If you have the audyssey microphone plug it and follow the directions to re-balance the equalization for the room and seating positions. If you don't use Audyssey, you'll need to tune all of the config setting manually. Some may be re-used if the distance is the same, but the loudness (+/- DB settings) and cross overs are probably going to be different for the new Klipsch speakers.
Jan 25, 2015 | Onkyo Audio Players & Recorders
Surround speaker
take back to be repaired under warranty asap this can happen. even if it's out of warranty they should repair for free if they stand by there product
Apr 10, 2014 | Onkyo TX-SR608 Receiver
I'm about to hook up my KLH to an Onkyo Receiver with Audyssey sound features. 2 questions: it asks me to set my sub to 75 DB. Since my volume dial goes 0-10, which number maps to 75 DB? Also, what...
I think it wants you to raise the volume high enough on the sub so IT can hear at least 75dB. It can always adjust the sub downward if necessary. Max it out at the sub and let Audyssey deal with the adjustment.
Your crossover frequency selection would be a piont below which you want the sub to activate. It depends on the bass capabilities of your other speakers. You want some overlap so there's no droop in the crossover region where your main speakers roll off.
Jul 13, 2011 | KLH ASW10-120 Subwoofer
Upon powering up my Onkyo TX-SR605 receiver, it enters Audyssey setup mode even though the microphone is not plugged in. Even if I plug in microphone and remove it, it still stays in Audyssey mode and I...
I have the same problem and it is not speaker wires, cables, or dumb remote codes (really, remote codes.) I'm taking mine in for repair, and not reliying on straw grasping, speculative solutions.
Jan 25, 2011 | Onkyo TX-SR605 Receiver
It appears that sometimes it takes longer for the picture to come up. A lot of times, before it does, the sound cuts in and out. The receiver says "audyssey" on it which I have never noticed before. Is...
I talked to a tech guy for onkyo and he said the delay is due to the heat produced from the unit. The hdmi connections take the brunt of the very hot running onkyo. Send it back in as it will only get worse. When you get it back make sure it has plenty of air flow.
Feb 10, 2010 | Onkyo TX-SR606 Receiver
Audyssey vs Direct switching on Onkyo SR606
Audyssey is the licensed feature this receiver uses for room and dynamic equalization. It sounds like the Audyssey process is activated. The manual says the Audyssey indicator "flashes during automatic speaker setup".
Has this unit ever worked or are you still setting it up?
Feb 09, 2010 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 bass treble settings seem to make no difference
I ran into the same issue and was stumped at first. Then I noticed somehow I had changed the sound processing to "Direct" which meant the signal coming from the source was bypassing all of the control in the receiver. All I had to do is select another option (press stereo for example on the remote) and kick it out of the direct mode.
Dec 21, 2008 | Onkyo TX-SR606 Receiver
Receivers
If it is me and I am spending that kind of money, it is going to be sick, os here is sick. 7.1 dolby surround and 1080P HDMI, 135W per channel, and right now if you go to FRYS.com, it is normally $500.00 bt for right now it is only $449.00. But if you put this in, be prepared to buy a PS/3 as your next investment (Th best way to get Blu-RaY at an affordable price, plus many other features) and an upconvert DVD layer, which is only about $100.00 or less today. Then you better get ready to hear from your neighbors and the cops, because they are going to think a war has broken out in your place. Enjoy, I play movies that the sound is just so realistic, I hate to leave the house anymore. Also, remember, speaker placement is key, so know the optimal environment for your system and if you need one, I may be able to hook you up with a system room tuning DVD for next to nothing. This will allow you to setup your system and place your speakers optimally for your environment. good Luck.
Onkyo TX-SR606B
7.1 A/V Receiver with HDMI Up-Scalling
Onkyo USA:
FRYS.com #: 5586420
The Progression of Affordable High-Def Home Theater Continues with Full HD Integration and Video Upscaling As part of the second generation of Onkyo high-definition-capable receivers, the TX-SR606 is at the forefront of affordable home theater. The key is to have the most capable version of HDMI. The TX-SR606 provides high-definition video and audio processing for four source components—another first for Onkyo at this level. From Blu-ray Disc players to gaming consoles and cable/satellite boxes, you have everything in the digital realm covered. Apart from 1080p video, the TX-SR606 can upscale all video signals to 1080i, regardless of the connection, for output via HDMI. Onkyo's own RIHD (Remote Interactive over HDMI) also gives you inter-operability with the displays and playback components from other leading brands. And with an expanded version of Audyssey's room correction technology, the TX-SR606 maintains the fullness of surround sound audio quality at low volume levels. The TX-SR606 offers all-round excellence rarely seen at this levelSpecial Features
  • HDMI v1.3a Repeater (4 inputs, 1080P compatible)
  • HDMI Video Upconversion
  • 1080i Upscaling powered by Faroudja DCDi Edge
  • TrueHD, DTS-HD Decoding
Amplifier
  • # Channels 7
  • Power (8ohms 20-20kHz 0.08%) /Ch 90W
  • Power (8ohms 1kHz 0.7%) /Ch 105W
  • Continuous 6ohms Rated
  • High Instantaneous Current Capability 36A
  • Amplifier Frequency Response 5Hz-100kHz
  • S/N Ratio (LINE IN) 106dB
  • All Discrete Circuitry
  • Absolute Ground Plate
  • Optimum Gain Volume
  • Non-Scaling Configuration
  • Bi-amp Capability For Front
Processing
  • DOLBY Decoder DD Plus, TrueHD
  • DTS Decoder DTS-HD Master Audio
  • Direct Mode
  • Music Optimizer
  • Audyssey Dynamic EQ
  • 192K/24 Bit DACs
  • DSP Type / QTY 32 BIT
  • Adjustable Crossover 40/50/60/80/100/120/150/200Hz
  • Independent Crossover
  • AV Sync
  • Accurate Speaker Distance Setting
  • Multi-Band Speaker EQ 5 Band
Connectivity
  • Audio In/Out 7 / 2
  • Digital Audio IN (OPT/COAX) 2 / 2
  • Composite In/Out 5 / 1
  • S-Video In/Out 4 / 1
  • Front-Panel A/V L / R / V
  • Component Video / Bandwidth 2 in / 1 out / 50MHz
  • HDMI In/Out 4 / 1
  • HDMI Version V1.3a Repeater
  • HDMI Bandwidth 1080p
  • HDMI Deep Color Capable (36bit)
  • Analog to HDMI Upconversion
  • 480i to 480p Processing (DCDi Edge)
  • 1080i Upscaling
  • Multi-Channel Input 7.1
  • Surround Pre-Outs SUB
  • Powered Zone2
  • Zone 2 Line Out
  • iPod Ready (DS-A2x, DS-A2, DS-A1)
  • SIRIUS Radio Ready
Integration Access
  • Onkyo-RI System Control
Miscellaneous
  • Pre-Programmed Remote
  • Glossy Black finished Remote
  • Simple Remote to change input & mode
  • Color-Coded Speaker Terminals
  • Auto Speaker Calibration W/Mic. (Audyssey 2EQ)
  • On Screen Display Out
  • Permanent Memory Storage
  • Solid Aluminum Front
  • Warranty 2 YEARS
Oct 13, 2008 | Audio Players & Recorders
Audyssey won't initialize the left rear channel speaker input during set-up
had the same problem found that the rear speakers were connected to the wrong inputs on the receiver, try changing them i think you will find that this will work
Aug 28, 2008 | Onkyo TX-SR605 Receiver
Open Questions:
See all Onkyo TX-SR875 Receiver Questions
Onkyo TX-SR875 Receiver Logo
595 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
