Question about Brother MFC-5840CN All-In-One InkJet Printer
Brother MFC-5840CN Hi, The LCD screen has a message saying unable to init. Please could you help me out. I have followed the user's guide and there are no faxes pending and nothing stuck in the printer itself as explaned on page 11-4 Troubleshooting and routine maintenance. I look forward to your urgent reponse. Mark
  • scpreschool Nov 05, 2008
    When I went into the menu as suggested it gave me "Machine Error 46". Can you tell what this is and how to fix it.
    Thank you,
    Beth
    Problem Solver:
  • 8 Answers
Press Menu, * 2864. That puts in in maintenance mode. If it flashes error 48, the flat ribbon to your head is broken. You'll need to replace the entire head assembly. Press 99 to leave the maintenance mode.
Posted on Sep 22, 2008
My brother printer is saying 'Unable to Init.'
This error message is sometimes due to foreign material under the printhead path or underneath where the printhead stops or parks.
Unplug the unit. Open the cover. Use a flashlight if necessary and carefully inspect the area underneath the printhead path. If the printhead is stopped or parked, gently move it enough to look at the area underneath. Common items are little bits of paper, staples, paperclips, push pins etc. Remove any foreign material.
Close cover. Plug in the machine.
Jan 21, 2010 | Brother MFC-5840CN All-In-One InkJet...
Unable to clean
you might try cleaning the grid on the drum cartridge with a fine brush like a painters brush
Jan 13, 2009 | Brother MFC-5840CN All-In-One InkJet...
[HELP] MY BROTHER MF-210C "UNABLE TO INIT"
Dear Guru,
I have a same problem" UNABLE TO INIT " but my printer DCP 110.
Please can help me.Thanks
Sep 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-5840CN unable to scan
From Brother Customer Service email:
You can try the following reset - it will most of the settings back to the default options.
Unplug power cord to the machine.
Press and hold down Menu.
Plug power cord back in.
Let go if menu when fax/scan/copy flash.
You may see either "maintenance" or "machine error xx" on the screen.
Type stop/exit, 9, 1.
The machine should show "param init" or similar to show that the reset is being done.
It will then go back to or machine error.
Type stop/exit, 9, 9.
This should take the machine out of maintenance mode and back to normal.
If the error is still present the machine will require an engineer to resolve the issue.
Jul 08, 2008 | Brother MFC-5840CN All-In-One InkJet...
PRINTER SAYS UNABLE TO PRINT USER'S GUIDE CHAPTER TROUBLESHOOTING
This is a common problem. If this is under warrenty get it repair or exchanged. There is a lot of people on here that are having the same Problem
Feb 13, 2008 | Brother MFC-5840CN All-In-One InkJet...
Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
Jan 10, 2008 | Brother MFC-5840CN All-In-One InkJet...
UNABLE TO INIT
MENU * 2864 VERY QUICKLY TAKES YOU TO MAINTANENCE MODE, ALL LIGHS FLASH... PRESS 82 SET, YOUR ERROR CODE WILL DISPLAY. THAT IS NEXT STEP.!!!!
Nov 16, 2007 | Brother MFC-5840CN All-In-One InkJet...
IT will not print.
Error message Unable to Change Unable to Clean Unable to Init Unable to Print Unable to Scan Cause The MFC has a mechanical problem. OR A foreign obstacle, such as a clip or ripped paper, is in the MFC. Solution Open the scanner cover and remove any foreign obstacles from inside the MFC. If the error message continues, please follow the steps below before disconnecting the MFC so you will not lose any important messages. Then, disconnect the MFC from the power source for several minutes (which will erase all faxes), and then reconnect it. Check whether the MFC has faxes in the memory 1. Press Menu/Set, 9, 0, 1. 2. If the MFC has no faxes, disconnect the MFC from the power source for several minutes and then reconnect it. OR If faxes are present, you can transfer them to another fax machine. Go to Step 3. OR You can forward the faxes to your PC. Please see Transfer faxes to your PC. Transfer faxes to another fax machine If you have not set up your Station ID, you cannot enter fax transfer mode. 3. Enter the fax number to which faxes will be forwarded. 4. Press Black Start. 5. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. You can transfer the Fax Journal report to another fax machine by pressing Menu/Set, 9, 0, 2 in Step 1 Transfer faxes to your PC You can move the faxes from your MFC?s memory to your PC. 1. Press Menu/Set, 2, 5, 1. 2. Using ▲ or ▼, select PC Fax Receive, and then press Menu/Set. The LCD will ask if you want to transfer a fax to your PC. 3. To transfer all faxes to your PC, press 1. OR To keep all faxes in the MFC?s memory, press 2. 4. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. (For details see Using Brother PC-FAX software on page 5-1 in Software User?s Guide on the CD-ROM.)
Sep 01, 2007 | Brother MFC-5840CN All-In-One InkJet...
Printer problem
MFC 5840cn - lcd shows 'unable to print see troubleshooting and routine'
Aug 20, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5840CN All-In-One InkJet Printer Logo
559 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
