Question about Sony KV-27S42 27" TV
TV is acting weird
My Tv turns on and off immediately. The standby/sleep light is flashing. but I can't turn it off...HELP!
  • 4 more comments
  • SACRIFICE Jul 10, 2008
    The light blinks 3 times...do I have to screw the back of the TV off? where do I get parts?
    IS THIS INFORMATION TRUE?
    THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby
    mode then displays the 3 blink fault. This is also a problem in the power
    supply circuit, check T603 and R672
    yes I got that info from another site and wanted to verify it. Thanks! now the next step for me is to find out what those parts are, what they look like and where to get them.
    T603
    R672
    thanks!
  • jsilauto Jul 28, 2008
    tv screen comes on then fades out can hear the volume no picture the red light blinks
  • dirtcheap Aug 21, 2008
    i have the same problem with my kv-27s42 sony.
    1) does T603 mean transister 603?
    2) does R622 mean resistor 622?
    3) are these solid state components in a solid state circuit board? if so, do i have to replace the whole board?
    4) will i have to drain the crt? if so, how?
Could be a memory error .try to turn on the tv after you extract it.If it is no change, than verify final flyback transistor (replace it).make sure that the power supply have the right tensions on secondary(could be higher than normal).
Posted on Jul 10, 2008
  • 4,234 Answers
The standby light should be flashing in a repeated count. That is what happens when the set detects a problem and enters a protective shutdown. The blink count will indicate the circuit in which the problem was detected. Please post that count and I should be able to provide you with details.
Dan
  • ABRsvcs Jul 10, 2008
    Yes, that information is correct. I don't have the manual with me at the moment, but that posting (from another site) is accurate. The part designation should be close if not exact. Please ignore the response from "guest" as that info is incorrect.
    Thanks,
    Dan
    I'll look up the parts in the service manual and post the part numbers and source here.
    Dan
My tv turns itself off and the standby light flashes
Check sleep option, may be somebody has set it mistakenly
Jan 16, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The tv sleep light is on and the tv wont turn on
my standby button keep flashing no picture but i do have sound for as long as 2 sec
Oct 22, 2010 | Akai CTS2550 25" TV
Standby light flashes but tv will not turn on
Ur high voltage is dying.The block of plastic with a red wire with a cap hook to ur CRT(tv tube).The FBT,it call the Flyback transformer,that is dying.That must be replace.
Sep 22, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Standby light is flashing 10 tims Model KV-HR36
Try unpluging your T.V. for 5hours+, then turn it back on. Worked for It's called a "hard reset" by sony.
Otherwise
Do the following steps
  1. Check the Sony remote for a button labeled "Sleep." This allows you to cycle through the sleep settings and determine how long you want the TV to remain on.
  2. Step 2 Press the "Sleep" button. You'll see a number come up onscreen: usually 15 or 90. When you press it again the number changes, moving up and down in increments of 15. This is the number of minutes the TV will remain on before it goes to sleep. As you cycle through it, you should see a setting with the words "Sleep Off" appear onscreen. If you leave it there, the sleep setting should cancel, allowing you to turn the set off when you like. If you miss it, just keep pushing the "Sleep" button. It will continue to cycle through the options until "Sleep Off" appears once again.
  3. Step 3 Access the timer function to shut off the timer by pressing the "Menu" button, then cycling through the onscreen options until you reach the "Applications" setting. Press it, and then cycle through to the "Clock/Timers" option.
  4. Step 4 Highlight the "Timer 1" setting and press the "+" button. If it's showing a given time, you'll need to deactivate it. Use the up and down arrows and move through the possible options until you come to the "Off" setting. Leave it there; that should shut the timer off.
  5. Step 5 Repeat the process with the "Timer 2" setting, a little further down the "Clock/Timers" menu. Set it to the "Off" position just as you did with the "Timer 1" setting.
  6. Step 6 Press the "Menu" button when you are done to exit the menu and return to the screen. You should be able to view the Sony TV as normal with no danger of it turning off.
good luck
Aug 08, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony TV Trinitron is on standby
standby light flashes tv wont turn on
Apr 11, 2009 | Televison & Video
Sony trinitron kv-27ts20 wont turn on
This problem may come from a bad capacitor in the standby power supply. The part location is C605
This should be an easy fix.
Cheers, CrazyLee
Feb 22, 2008 | Televison & Video
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
TV will not turn on
check the items listed in the image to locate the 5 blink error. good luck.
Jan 03, 2007 | Sony KV-36FS16 36" TV
Sony KV-27S42 27" TV Logo
133 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
