Question about Dell Dimension B110 PC Desktop
My computer keeps shuting down. When I try to restart it - the first screen says - Alert! Previous shutdown due to thermal event.
Alert! Previous fan failure.
Am I to assume that I need a new fan?
  • 37 Answers
Dell dimension 3100 keeps rebooting
1. Click Start > Run and type REGEDT32 and hit ENTER
2. Click the plus sign next to HKEY_LOCAL_MACHINE
then System
then CurrentControlSet
then Control
then click CrashControl
3. Double-click on AutoReboot on the right side and change the value from 1 to 0.
Close regedit and restart the computer. Now the computer should shut down normally instead of restarting.
Feb 26, 2012 | Dell Dimension 3100 PC Desktop
I have a problem with my Dell Dimension E520 computer freezes after 15 minutes of being turned
hmm..try check your bios...look at your cpu performance or shuting down temperature...maybe u can disabled shutdown temperature at your bios...or make default setting cmos setup..try that
Jan 15, 2010 | Dell Dimension E520 PC Desktop
Dell b110 when I try to turn it on the light blinks consistently yellow
Try a different power supply in the computer if you can. Get a known working one cause its possible that your current power supply isn't putting out the right voltages.
If you try another power supply and you still keep getting the blinking yellow light then that means the motherboard is bad.
Nov 30, 2009 | Dell Dimension B110 PC Desktop
Mouse and keyboard suddenly stopped working on Dell b110 desktop
Disconnect external peripherials except keyboard and mouse .Disconnect the power cable.Hold the power button for 10 seconds to drain flea power.Reconnect the power cable and turn on the computer When the blue DELL™ logo appears, press immediately. In bios there is option for Function key F9 or F10 probably to reset to defaults.SAve and exit and restart the system .Then try to use the PC restore feature on dell. check http://support.dell.com/support/edocs/systems/dim1100/en/SM/syssetup.htm#wp1055545
Good Luck.
Apr 05, 2009 | Dell Dimension B110 PC Desktop
Blue error screen and system shutdown on Dell Dimension C521
Rule of thumb test ram out first usally that is the cause what does the code say on the blue screen
Feb 13, 2009 | Dell Dimension C521 PC Desktop
Shut Down Problem & Have to Reset Computer Battery
Hi, I had the same problem, for a workaround this is what I did. I made a new shutdown shortcut. Now when I click on it the pc shutsdown fine. I actually put mine on the taskbar. Here's how I did it...
XP Users:
1. Right click the Desktop and select New /Shortcut.
2. A screen will appear asking you for a Command Line. Here's what you put in that box:
For Shutdown:
Shutdown -s -t 0
For Restart:
Shutdown -r -t 0
For Log Off:
Shutdown -l -t 0
After you've decided which of the above options to use, click the Next button and give the shortcut an appropriate name.
Final Notes:
1. Now that you have the nifty little shutdown shortcut on your desktop, you may want to drag it to your taskbar for easier access (and less chance of accidental clickage).
2. I didn't like the nasty looking icon that XP gave my shortcut (it was too Win3.1 for my taste), so I changed it.
If this helps you plz rate this 'fixya'. If not leave a comment & I'll be happy to try to help you further. Thank you kindly.
Feb 12, 2009 | Dell Dimension™ B110 PC Desktop
Dell dimensio B110 computer does not start beyond the startup window
while the pc is booting up hit F8, it should take you to a sub menu, choose "last known good configuration" and hit enter, see what it does.
post back please
regards
Nov 27, 2008 | Dell Dimension B110 PC Desktop
My screen goes blank immediately after initial DELL startup image
You can either try to reset the BIOS, or have the restore cd fix it for you. By the way, what does the message say?
Fan Malfunction??
Sounds like a heat issue, pop the side of your case open and turn on the PC, are there fans not moving? Take a close look at your processor fan if there is one.
Jul 10, 2008 | Dell Dimension B110 PC Desktop
Dell Dimension B110 PC Desktop Logo
303 people viewed this question
Alun Cox
