Question about Zebra Eltron P330i Card Printer
LCD display fault (blank) on Zebra card printer
Hi ginko,
Thanks for your prompt response.
To be honest I'm not sure if the printer is printing badges, which I can certainly check later this eve'.
I've tried the printer without PC connection, although the problem remained the same.
I've also had the power off a few times (for 2 mins & more), although the fault persisted.
Yes, with the printer as `stand alone`, the display screen is still lit up, albeit still blank. Oh dear, I hope it's not as serious as the main pcb board, fingers crossed.
I'll connect it up later and try printing and report back how I got on.
Thanks!
  • Gixer-Rider Jul 10, 2008
    ginko,
    I tried the printer and was so pleased to see that it prints ok.
    Therefore I'll check the connection on the printer's ribbon-cable.
    Cheers!
  • Zebra Master
  • 19,396 Answers
If the printer has blank lcd on standalone this means it is not a computer or system related problem.
Reversing your diagnosis on previous post:
In the Best case it is just a faulty lcd, or lcd ribbon out of place or broken. The relay thing does not make much sense, it is easier to think that it may be any faulty capacitor or IC on main board.
Basically if it prints it is for sure the lcd (display or cable). You can chose to take printer apart or to use it like this, if it does not print or is not recognised by computer, then printer is faulty.
Posted on Jul 10, 2008
Hi all~ my zebra printer print blank non-stop everytime power on printer. we need send jobs first just can power on printer to stop printing blank non-stop.
When you power that printer on it will automatically calibrate which can kick out up to 6 feet(2 meters) of blank labels. After that is done if you have an issue it should display an error.
Sep 29, 2015 | Zebra 203DPI Printer
Hi. We use UPS worldship and we have a Zebra Z4MPlus printer. It is shooting out a blank label after one label is printed. When there are multiple packages it will spit out way too many labels with blanks...
Things to check for:
1. Make sure that label guides are positioned correctly.
2. Make sure that media sensor is positioned correctly.
3. Make sur that media type is set for non continuous labels.
4. possible sensor fault tis will require an engineer.
Hope this helps.
Aug 22, 2011 | Zebra Office Equipment & Supplies
I have Zebra P330i printer, have done the cleaning using short and long cards. Display shows "Ready". On printing using color ribbon, the messages (Printing Yellow, Printing Magenta...)appear on...
Knowing that you were able to complete the proper cleaning procedure using the short and long cards, and the printer is on ready status, try to change the ribbon and test. Make sure the card is properly inserted with the magnetic stripe on the top facing down. Also make sure that the ribbon is properly loaded. There should be an instruction on the cover for its proper orientation.
If it still does not print, make sure your configuration on the printer is set to the proper type of cards HICO or LOCO and the ribbon type is properly set to YMCKO for color. Also, check if you have enabled mag stripe encoding or if you don't need to have it enabled. Enabling means that the printer will check for the mag stripe if its good or bad. If bad the printer will reject the card.
Do a self test print by following the below. 1. Set the printer's power switch (on the back of the printer) to the OFF ( O ) position. 2. While pressing the Printer's front panel button (next to the LCD display panel), switch the printer ON ( ' ). 3. Hold the panel button until the LCD display panel reads "SELF TEST". 4. Release the panel button, and the test card will print
If no prints, observed for any mechanical errors on the printer. Normally mechanical errors are detected by the printer with corresponding error message.
If none of the above works then you might have a print head problem. You may attempt to clean it by following below. Else if it does not help then have your print head replaced.
A cleaning using the Cleaning Cards usually suffices. However, a separate Print Head cleaning can remove more stubborn deposits when print anomalies persist. To avoid deposits, only use foam-tipped swabs. 1. Place the printer power switch in the OFF ( O ) position. 2. Open the Main Cover, release the Print Head Carriage, and remove the ribbon. Leave the Print Head Carriage in its raised position. (For details, see Chapter 2.) 3. Clean Print Head by moving an alcohol-moistened swab tip side-to-side across the Print Head elements. Only use moderate force. To re-order swabs, please refer to the Media List on the Windows Drivers and User Documentation CD supplied with this printer. 4. The swabs can also be used in a similar manner to clean the optional magnetic encoding head.
Jul 12, 2011 | Zebra P330i Thermal Card Printer
Zebra p11oi will not print anymore
Make sure you have the ribbon set right in the driver. If the driver says ribbon X, and the printer is loaded with printer Y, it won't print. (Make sure any driver settings are done while logged in with Windows Admin rights - "regular" users don't have sufficient privileges to make driver settings changes).
Also, check the printer queue and device settings. Make sure there are no jobs stuck in the queue ("Cancel all documents"), and make sure the printer is NOT set to "Use Offline" or "Pause Printing".
Other than these items, it could just be that the printer has lived its life and ready to be put out to pasture. Feel free to contact us for other questions, or to consider replacement options.
Jul 26, 2017 | Zebra P110i Led Card Printer
Hi I have a Zebra ql220 printer that prints about 4 or five blank labels in between barcodes. Is there a way to manually adjust this via the printer. I got a message on one printer about bar gap sense not...
Press and hold feed button for 2 -3 seconds and switch on printer.Printer will calibra and print test page .if problem is not solved Go to printer menu and select ribbon and media calibration.it will calibra te printer and problem will be solved
Aug 03, 2009 | Zebra Printer 140-751-00000
Feedig problem
Make sure your image is only 1 page.
Possibly the printer is printing the second page blank.
I know you are most likely printing a single card.
But some times LARGE fonts or LARGE images will print as 2 Pages.
Check it out.
Let me know.
Regards
May 27, 2009 | Zebra Eltron P310 Thermal Printer
Broken ribbon message for my zebra card printer
It could mean that the ribbon sensor on the printer is broken. Sounds like you need to send back to zebra for repair. This is free if printer is still under warranty. check out zebra's website for info on how to return printers for service.
Sep 11, 2008 | Zebra Eltron P330i Card Printer
Zebra Strip prints blank labels
Please download a new driver from www.zebra.com (don't use your old windows driver) and then this will fix the problem.
Sep 05, 2008 | Zebra Stripe S600 Thermal Label Printer
Zebra Eltron P330i Card Printer Logo
336 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
