Hello,i need to register my compaq computer.the dialing procedure keeps disconnecting.i only have local service on my phone and no long distance service available.what can i do to get this register complete?
  • 37 Answers
There should be an 800 number to register with.
Posted on Jul 10, 2008
Do I have to dial 9-1 before the area code when faxing?
Hello, If you are in an office or corporate environment where the phone system is on a PBX you need to dial 9 usually to get outside the office. If you just have the unit setup at home or to an analog phone jack (not going thru a PBX) then just dial 1 + area code + number. If the number is local then don't use a 1, just the phone number and area code.
Chris
May 11, 2011 | Ricoh Aficio CL3500N Laser Printer
I can dial local calls and receive local and long distance calls on my GE 27990GE3 but can not dial long distance. After dialing the long distance number I just get a dial tone.
that doesnt sound like a problem with the phone it seems like it is a problem with your provider give them a call they can sort it out good luck
Nov 11, 2010 | GE 27990GE3 Cordless Phone
What do i dial before the long distance number a 1 or a 9
Depending on your phone service. if you pick up the handset and dial a local number without using 1 or a 9 it should be fine. You basically would dial how you would make a call from your phone. Long distance included. If it is a long distance number from your phone, it would be for the fax machine too.
Feb 10, 2010 | Lexmark X4270 All-In-One InkJet Printer
We are having problems with our Muratex F110 fax machine. It won't send long distance faxes. the phone company says it is not on their end. any suggestions?
Well technically it's not on thier end. Let's remember that a fax uses a normal home style phone line.
So ask yourself these questions.
#1 Do I have long distance service on this phone line?
#2 If I do have long distance service do I need to do any kind of special dialing sequence to access long distance? Like a 9 or an 8 or any other number before dialing outside of your local area.
In some cases( businesses usually) a special code needs to be entered after dailling the number.
Most fax machines have a hansdset on them. Do this simple test. Lift the handset and dial a known long distance number and listen to what the operator message says. If all else fails call your phone company and ask them if this line has long distance capability.
Sep 22, 2009 | Muratec Office Equipment & Supplies
LAND LINE TELEPHONES: Can you not assign a long distance carrier?
Yes you can have your phone set to local calls only.
You have to speak with your service provider and tell them you no longer wish to be able to call long distance from your house phone. but still want local calls only.
Jun 13, 2009 | Vtech 9009111 Cordless Phone
Phone dialup-local phone service
You do not need a dial-up internet connection to use fax. All you need is a working phone line. Beyond that it works like a phone call (think of it as one fax machine calling another fax machine), so if your plan allows you to call locally only, then you can only fax locally as well. If you try to fax long distance, it may or may not work based on whether you can make a long distance phone call. Also, you will be charged for long distance calls if you fax long distance. These fees have nothing to do with Lexmark or whatever brand your fax machine is, it is the phone company that will charge you.
May 10, 2009 | Lexmark All-in-One Printer with PictBridge
No dial tone
Have you replaced the phone cord to the wall? if not start here, if the base has not been dropped or wet, try resetting it.
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
<KEYWORDS="RESET, call,? can?t tone, dial no flashing, unavailable, range, of out working, not up, messed>
Hope this is of some help.
Ed
May 05, 2009 | Lands Phones
I can't make long distance call?
Is this a recording, or does the phone display this ?
If this is a recording, it is from the long distance provider. Did you change long distance companies lately?
Call your long distance company....this is their fault.
Nov 13, 2008 | NorStar Meridian M7310 Phone
Faxing Long Distance
To my knowledge, if the unit can send a fax message to another fax machine then it is safe to assume that there is nothing wrong with the fax.
Perhaps your problem may be more related to the type of phone subscription that you may have. Some phone providers have subscription for local calls only and restricted long distance. Alternately, there are some phones that would need a series of numbers to be pre-dialed before long distance access is granted.
Pls check with your local phone company. Additionally, you can try by calling long distance using your regular phone and see if it works. If it does, then long distance restrictions has been imposed/enabled in your Canon 3300. The procedures are better explained in the users manual. A copy of the user's manual for Mac users is here, all other downloads including those for Windows, is here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 18, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
No longer dialing Lond Distance
If your modem can fax a local number or dial-up an Internet Service Provider in your Local Area then your Internal Modem is just fine. Check if the configuration of your Modem to access outside long-distance number. Go to your Control Panel-Open Phone & Modem Options-Dialing Rules (Tab)- then click on EDIT Button. You can enter the number needed to have a long distance dialing. If you don't know the number needed for long-distance dialing then ask your Local Phone Service Provider.
Apr 04, 2007 | Smartlink (I56KSPF00) Modem
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
