Operating syatem not found
Kindly help I have a Samsung M60 laptop. After i removed the 200gig hdd sata and did a data recovery on lost data the hdd refused to boot when i put it back it is not even being detected by the bios it only says Operating system not found I will be greatful for your help. The software i was using was stellar phoenix and the HDD connects to the M/Board via a ribbon connector
Thanks in advance
    Problem Solver:
  • 5 Answers
How did you do the data recovery ?
i bet you put it into a desktop and did it that way ??
what you have basically done is taken the boot sector information off the hard drive. you need to get acronis boot manager or partition manager and install this as it will help restore your boot sector in your laptop and needs to be set to primary partition.
Posted on Jul 10, 2008
Samsung NP355E5 not boot from HDD.
You may find best results finding Samsung support for this at...
http://www.samsung.com/us/computer/pcs/NP355E5C-A01US-specs
If this, my reply helps, you may show that.
A
Jun 28, 2017 | Samsung Computers & Internet
LaCie Rikiki USB 3.0 connection broken
Can you open the case and remove the HDD? I looked at the specs on the device and I didn't see what interface the drive is, I would assume it's a SATA, I don't know for sure. Can you ID it? You can get a USB 2.0 to IDE/SATA Adapter: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3276554 You can remove the HDD, here are some examples : http://www.ultraproducts.com/applications/category/category_slc.asp?CatId=2781&name=2.5
>>>>I found the specs on the HDD inside, it is a SATA, (samsung hm500ji) : http://www.newegg.com/Product/Product.aspx?Item=N82E16822152168 , You can use the adapter to remove data and erase HDD and return for replacement under warranty.
Dec 19, 2012 | LaCie 500GB Rikiki USB 3.0 Portable Hard...
I have a Samsung HM640JJ HDD. I bought the drive as an external in an enclosure. The drive has stopped spinning all-together. I even tried to put the HDD in my laptop but will not spin. Samsung will not...
If the hard drive can't be detected by your computer, you can try this way.
Put the hard drive in a plastic bag to be compatible for the freezer. Freezing sometimes works to revive a dying hard drive, at least for a short time(Probable just about 20 minutes), but be sure that the bag is sealed tightly so that condensation and ice crystals don't form. Put it in your freezer for 24 hours that will do the trick. While it's still cold, plug it into your computer.And you may be able to view it in 'my computer'.
If it shows up in 'my computer' as a drive letter(like E: drive) but you can't access it,you can recover data from hard drive with data recovery program.
Tenorshare data recovery is a professional data recovery program that can recover data after deeply scanning your hard drive to look for lost data due to drives crash, physical damage,system sabotage, virus attack etc.You can get it here: http://www.any-data-recovery.com/product/datarecoveryprofessional.htm After you recover your data,you can format it to check out whether it can be fixed.
If it fails, you will have to go to a recovery office where supply data recovery service but let's hope not because it will cost you a lot of money and whether they can recover data is not guaranteed.
Aug 27, 2011 | Samsung Spinpoint MP4 HM640JJ 640GB 7200...
My Hp laptop dv2402ca got a message on start up saying that it needs recovery or start normally, start normally is not working and i need the data from the Hd so i can't do recovery after i put it on sata...
well get an external hdd cAsing, remove the hdd from ur laptop and put it into the casing , caonnect the same to any other machines, if u can see ur data then great, if u cant then break all the partations of ur hdd an create a fresh one partation , download and install get my data back or azure data recovery software ( google it ) and put ur hdd on recovery... u will be able to recover max 90 % of the data
best of luck
Jan 08, 2010 | HP Pavilion dv2000 Series Laptop Full...
The hard drive is not being detected on our laptop it turns on and everything but its not being detected what is the problem its not even a year old yet.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
http://www.asoftech.com/adr/
Oct 09, 2009 | SimpleTech 1TB SimpleDrive USB 2.0/eSATA...
SATA hard disc compatibility
Actually, there are two good reasons not to swap that drive into the new laptop,
First, you never want to boot from or install software to a drive you're trying to recover as everything you do to/with the drive runs the risk of causing further damage.
Second even if it weren't for the damage, you simply aren't likely to have the right drivers unless both laptops are the exact same model.
My suggestion is just get the new laptop you want, then attach the damaged drive with the enclosure to the new laptop then run your recovery software. If that doesn't work, you will likely need the help of a Pro.
Try Armor-IT Data Recovery, they are listed in the FixYa database and service clients from all over North and South America.
Hope this helps FixYa,
Chris
May 19, 2009 | Computers & Internet
Installing win xp and vista together on dell 1537 studio
you will not be able to put os in the same hdd on a computer.also if vista is installed on one hdd & the other partition is on the same hdd so please try not to install 2 windows on same hdd,its not possible...
Apr 24, 2009 | Dell Studio 1537 Laptop
Samsung 80 gb Hard Disk Un allocated
All ways best to used new cables (sata/Ide) I like to set jumpers on the HD's never cable select. Also try installing one harddrive at a time. Second make sure in bios is set to boot from main HD.
May 12, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Samsung 200gb hdd
When u bought a new hdd, it shud not have any partition on it. but in ur case, I assume u have formatted it to ntfs but no operating system is installed in it.
If u want to make the new hdd as slave and have another old hdd as primary, that have already an operating system installed in it, then the problem shud be hdd boot priority in bios. Enter ur bios and check for hdd boot priority and put the old hdd to the top most order, then restart. this shud fix the problem.
If u installed OS in ur new hdd (win xp),
1) ntldr or ntdetect.com is missing on root dir. (c:\). If u have another computer that works and have xp installed, just put this new hdd along with the current hdd and boot to windows. Copy ntldr and ntdetect.com to your new hdd. Or another way is just repair using windows xp boot cd.
2)the windows partition is not set 'active'. to set active, boot into winxp setup and press 'r'. this will lead to recovery console. type ur passwrod for admin (def=none). use diskpart command to set active. for easy way, put the new hdd to another computer. boot to windows. rightclick my computer, choose manage. on left pane select disk manager. rightclick on ur partition, then set active.
Hope this help
May 08, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Hard Disk Drive Not Detected
Does your hard drive get detected in the BIOS? If yes then you can recover data by plugging that hard drive as secondary and running a recovery application like Recover My Files.
Dec 23, 2007 | Seagate (ST3160827AS) 160 GB Hard Drive
Computers & Internet Logo
128 people viewed this question
David Payne
David Payne
