When I attempt to email a document, the following is the message I receive: Some errors occurred while processing the requested tasks. Review the list of errors below for more detais. The host could not be found. Please verify that you have entered the server name correctly. Please advise how I can go about fixing this problem. Thanks!
  • 37 Answers
Looks like you do not have the SMTP server settings correct. Have you tossed mail from this account before? Who is your ISP? What email program are you using? (Outlook, Outlook Express, Thunderbird.... list goes on)
Posted on Jul 10, 2008
Netflix error 405
http://forums.mozillazine.org/viewtopic.php?f=38&t=605984&p=3155060
http://www.checkupdown.com/status/E405.html
SYMPTOMS
When you browse the default document, you receive one of the following error messages: HTTP Error
405 Method Not Allowed
The method specified in the Request Line is not allowed for the resource identified by the request. Please ensure that you have the proper MIME type set up for the resource you are requesting.
Please contact the server's administrator if this problem persists.
HTTP 405 - Resource not allowed
Internet Information Services
This problem occurs if the following conditions are true:
  • You do not specify the file name. For example, you do not specify http://Server/Web/.
  • The Scripting Object Model (SOM) is enabled.
  • A DTC event is called.
CAUSE
This problem occurs only when you use Microsoft Internet Information Services (IIS) 4.0 and Microsoft Internet Information Services 5.0. This problem occurs if you send a POST request to a server that is running IIS 4.0 or IIS 5.0, and the POST request contains a URL that ends in a slash mark (/). IIS returns the 405 error message instead of the default document. However, if the method value of the Verb property is GET or HEAD, IIS returns the default document. RESOLUTION
When the SOM is enabled and a DTC event is called
When the SOM is enabled for the page, a <FORM> tag that is similar to the following is inserted in the page. <FORM name=thisForm METHOD=post>
Because no ACTION attribute is specified in the tag, both Netscape Navigator and Internet Explorer try to make an HTTP POST request to the URI "web/". According to the HTTP RFC (RFC 2068), this is not a valid Request-URI for a POST operation.
To work around this problem, use one of the following methods:
  • Redirect from the default document to a different document. In this case, the SOM-enabled document will no longer be the default document. The new default document will just redirect to the SOM-enabled document. For example, if your SOM-enabled document is named MyDefault.asp, the default document (Default.asp) will contain only the following code. <% Response.Redirect "mydefault.asp" %>
  • Use client-side script to make sure that the file name is included in the URL. If you must use your SOM-enabled document as the default document, use a client-side code block that is similar to the following code block as the first code block within the <HEAD> section of the page. This code block does the following location replacement. Language=JavaScript> var loc = document.location.toString() var loclen = loc.length //The name of the default document var filename = "default.asp" var filelen = filename.length loc = loc.substring(loclen - filelen, loclen) if (loc.toUpperCase() != filename.toUpperCase()) { location.replace(filename) }
When the remote scripting is called
This problem may occur if you use the window.location.href property in an HTML document to determine the path of the current document. If you do this when you initiate a remote scripting call, the remote scripting call fails because the client page does not have a file name.
To determine whether the page can use remote scripting on the client, verify that the value of the window.location.href property does not end in a slash mark. To provide a file name in the client browser, and to prevent the error on the server, use the Response.Redirect method redirect the request from the default page to another page. For more information, see the first resolution method in the "When the SOM is enabled and a DTC event is called" section. STATUS
Microsoft has confirmed that this is a bug in the Microsoft products that are listed in the "Applies to" section.
This bug was corrected in Microsoft Internet Information Services 6.0. Properties Article ID: 216493 - Last Review: 11/21/2006 13:13:42 - Revision: 3.2
Applies to
  • Microsoft Internet Information Services 5.0
  • Microsoft Internet Information Server 4.0
Keywords:
  • kbbug kbctrl KB216493
Apr 20, 2014 | Netflix Computers & Internet
Object reference not set to an instance of an object. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information a
change PDF readers program.if yuo absolut want adobe acrobat uninstall it download new version.install that but be sure of get out all old files.in C\
Apr 01, 2013 | Computers & Internet
Unable to remove on screen rec d in memory
Receiving Documents in Memory While Performing Another Task or When a Problem Occurs
If your fax is performing another task or encounters a problem when receiving a document, it
automatically stores the unprinted pages in memory, and the LCD displays MEMORY> as well as one or more messages. For an explanation of the message(s) and details
on the action to take, see page 64.
If you would like for me to send you the user manual, please send me an email to LBrown18062@hotmail.com Put CANON FAX JX200 as the subject and I will send it to you right away.
Oct 21, 2011 | Canon FAX-JX200
Good day, We have microsoft office 2007 installed, it work perfectly, and suddenly it stopped working and threw out an error box that reads as follow; [ This modification is not allowed because this...
This behavior may occur if the document is protected with an editing restriction of No changes (Read only) or Comments.
Word 2007
* On the Review tab, click New Comment.
Note If you insert your comments in this document, you can save your changes and then return the document to the sender with your comments.
* In the Protect Document task pane, click Unrestricted Access.
Word 2003
* On the Insert menu, click Comments.
OR
* On the Protect Document task pane, click Stop Protection.
Note If the Unprotect Document dialog box appears for you to type a password, the document is password-protected and you cannot stop the protection on this document unless you know the password.
Mar 14, 2011 | Microsoft Computers & Internet
I cant put anything in msword...it appears in the right bottom the word "This modification is not allowed because the selection is locked?" ...what should i do? I also lost my product...
Try to open your word document with Word Password Recovery 5.0
This Word Password Recovery program recovers Password to Open and removes Password to Open and Password to Modify easily for Microsoft Word of all versions from 97 to 2007.
source(s):unlock word password
Nov 06, 2010 | Microsoft Computers & Internet
I can not get the printer to stop printing ...what do i do?
Hi please turn off the printer and restart it after five minutes if you still have the problem please uninstall and reinstall the drivers for your printer.
Jun 13, 2010 | HP Office Equipment & Supplies
I can not install the program for the Digital Arts & Crafts Studio on my computer for my 4 years old daughter. During installation process I have the following error message: Error 1317 an error occurred...
This error is related to directory permissions and you might have to change some registry settings which is a complex task so it's better if you first try this very effective workaround.
While installing this software, there muist be one step where it is asking for the location to install. At that step chsnge the installation location as
Assuming you have XP
c:\documents and settings \(Your user account name)\Digital Arts\
In case if you have vista
c:\User\(Your user account name)\Digital Arts\
Dec 25, 2008 | Computers & Internet
ActiveSync from my phone
Thinks jbrickman For ask Me !
Here is Another Problemes about This Phone
icon_ea.gif Error occurred accessing attachments. Verify attachment settings - Inbox Tools/Options/Storage. You should also verify that you have sufficient free storage space. icon_error.gif icon_ea.gif COM Error 80070002. icon_error.gif icon_ea.gif ..\CEOutlookTranslator\MapiFields.cpp 2333 icon_error.gif icon_ea.gif ..\CEOutlookTranslator\MapiFields.cpp 2423 icon_error.gif icon_ea.gif ..\CEOutlookTranslator\PFolder.cpp 817 icon_error.gif icon_ea.gif Error occurred while getting email field. icon_error.gif icon_ea.gif Subject of bad email: 080303 WebEx_Overview_.ppt icon_error.gif icon_ea.gif Bad email received: 3/5/08 6:00:27 PM icon_error.gif icon_ea.gif ..\CEOutlookTranslator\PFolder.cpp 679 icon_error.gif icon_ea.gif Error occurred while getting Inbox records, records Processed = 45 icon_error.gif icon_ea.gif COM Error 80070002. icon_error.gif icon_ea.gif ..\CEOutlookTranslator\PFolder.cpp 2957 icon_error.gif icon_ea.gif Error occurred while getting captured Inbox changes, changes Processed = 0 icon_error.gif icon_ea.gif COM Error 80070002.
And The SOlution Here IS :
The way to sync with Exchange Server (as detailed in the documentation that came with the phone and as I have it set up following those instructions) is:
- You go to the verizon wireless website, create your verizon account, enter all the details for your exchange server (address, username, password, etc).
- The VZW server pulls info from your exchange server and then the VZW server sends this info to your handheld.
You may want to call VZW tech support if you are having difficulty setting it up.
And Thanks
Aug 28, 2008 | Apple iPhone 3G
"Can't connect to email server, make sure you have an Internet connection"
Whenever a mail server is unable to process an e-mail request, the e-mail fails and the software displays one of the following error messages: Can't connect to email server Progress bar stuck at 0% To resolve this problem go to http://www.kodak.com/go/itg
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
E-mail pictures using Kodak EasyShare software
when I send a picture, the envelope shows sending but it never goes thru to the recipient.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
