An "a-coil" is a cooling coil that looks like the letter "a". The cage is simply the box or sheet metal case built around the a-coil. It is most likely located inside of the furnace itself and if you remove the furnace door you should be able to easily locate the coil- it has 2 copper pipe tubes running from the coil and down or up through the ceiling or the wall.
Hope this helps,
James
Testimonial: "Thanks very much. I have ask everyone Iknow and got no answers. This has really helped me out. Paul"
