Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Harley start trouble
Yes the lights are fine, battery is fully charged (also tried car battery to verify). I agree it must have something to do with the starter but it seems strange it won't turn over all all when the plaugs are in but when I remove them (leaving the caps on) they fire and the engine turns over.
You wrote:
Probably starter/solenoid contacts needs to be cleaned or somthing from it sitting. Could even be the starter relay. If everything else seems to work on the bike then its probably something with the starter system.
    Genius:
  • 2,028 Answers
Just your average run of the mill bad starter. When you take the plugs out, you relieve all the compression from the cylinders, therefore there is no load on the starter, and it turns it over. Put the plugs back, and you get the compression back, putting a tremendous load on the starter. Replace the starter and you're good.
Posted on Aug 06, 2008
How does semi charged battrey cause electronics to go mad
charge your battery as the computers do not operate correctly if battery voltage is to low.. there is no reset just put in a fully charged battery.
Jul 13, 2014 | 2003 Renault Megane
If ignition on and start button pushed,oil light and nutrail light go out and no start.
is battery fully charged and have you had a drop test done to test the cells are not bubbling up showing weak battery ? can you hear a click when you press start , if yes then change starter solinoide !
May 26, 2014 | 2003 Harley Davidson FLHR Road king
Starting problem
Hi Anonymous, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to Ignition
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
For a prime suspect please visit website below and good Luck.
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Jan 01, 2014 | 2010 Harley Davidson FLHX Street Glide
Headlights not working, rpm gage not lighting up, neutrel light not coming on
Harley Davidson Sportster error codes and how to access them
Dec 15, 2013 | 2000 Harley Davidson XLH Sportster 883...
2003 Harley xl 883 wont start, what haven't I thought of?
Hi Mystr_e119, you may have a faulty CKP sensor, for more information about your question please visit the websites below. Good luck and have nice day.
http://harleymanual7.blogspot.com/2011/05/how-to-test-harley-crank-position.html
Jun 17, 2012 | Harley Davidson XL 883 R Sportster...
I have a 95 isuzu rodeo v6. it was having trouble starting. today it would not start. battery/brake light came on. found out starter was bad, replaced it. the light is still on and after replacing starter...
possibly wrong termination of wires @ alternator.
to drop off a battery cable is one old and reliable way to check charging system. if belts are tight and wiring is correct it is time to put a meter to alt and verify output voltage is within acceptable ranges.....
Nov 01, 2010 | Isuzu Rodeo Cars & Trucks
Bike was left on and battery fully discharged. It
Were you having trouble with the battery before this incident? If not, then charge the battery with a charger...NOT a trickle charger...for 12 hours. After this, check the voltage with a volt-ohm meter, it should read 12v -14v. Install in the bike, connect and check it again with the volt-ohm meter, it should hold the same reading as off the bike.
Try to start the bike, if it starts, check the battery again, now it should read 14v or a little more. Turn everything off and try to start it again. If it starts, the battery is still good but don't leave it on like that anymore.
If you get anything less than 12v after ther charge, the battery most likely has a dead cell and needs to be replaced.
Sep 06, 2009 | 2000 Harley Davidson FXDWG Dyna Wide Glide
Engine Light Going On/Off
yes it could cause this
fully charge battery and try again
Apr 04, 2009 | 2002 Harley Davidson FXD Dyna Super Glide
Lands Phones Logo
190 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
