Question about Car Audio & Video
I installed an "Audi 6-disc changer" in my 2001 A6. The installation went without a hitch..connection and bracket mounting was fine... it performs as expected except it seems to be extra sensative to bumps in the road.. and consequently it frequently "skips" and is somewhat annoying. Any advice as to how to lessen the effects of these bumps and skips?
    President:
  • 624 Answers
Most CD changers for cars have setting for the internal springs. The springs are postioned one way for a vertical mounting and 90 degrees different for a horizontal mounting. If this is incorrect, set for vertical when it is mounted horizontal or vice-versa, the unit will skip very easy.
I am not familiar with the Audi changers, I repair only aftermarket changers like Kenwood, JVC, Sony ect. but they all have a mounting direction setting on the sides of the changer. It can be adjusted with a flat head screwdriver. Try looking for this setting on the outside edges of the changer.
I hope this helps and a "FixYa!" rating would be appreciated if this free help solves your problem.
Thanks and let me know if I can be of any more assistance,
Dave
Posted on Jul 10, 2008
A6 turbocharged. Whyu does it smoke when it covers a 120km per hour?
I am going to say 'blown turbo'. As I understand it, they needs replacing every few years. They are susceptible to heat and incredible revolutions. They have to be lubricated, the seals go, and you get smoke.
Mar 20, 2016 | Audi Cars & Trucks
Kenwood 6 disc cd changer
screw needs to be replaced and making sure the bracket it not bent... thus , not allowing the cartridge to come out,,,
May 12, 2014 | Kenwood KDC-C465 6-Disc CD Changer
Audi a6
It sounds a lot like either the bulb went out or the fuse is blown. If there isn't anything else out it's likely the bulb, otherwise, check your fuse panel.
Jun 09, 2013 | 2001 Audi A6
My TT was imported new from Japan....Has AMAZING video and sound system unfortunateley its all Japanese to me!! The manual that comes with it is about an inch think...Its got built in Navigation system...
I know you can that you can change this by simply hooking up a scan tool for specific year. There are language options accessible for situations like this. Here is a sample of what can be changed using VAG 5052 or equivalent scanners.
Coding
  • 0?xxxxx: Model
    • 1 = Lamborghini
    • 2 = Audi A3 (8P)
    • 3 = Audi A4 (8E)
    • 4 = Audi A4 Cabriolet (8H)
    • 5 = Audi A6 (4B)
    • 6 = Audi TT (8J)
    • 7 = Audi R8 (42)
  • 0x?xxxx: Treble Speaker Monitoring inactive
    • 0 = Front Treble Speaker Monitoring inactive active (NOT Audi A4 Cabriolet)
    • 1 = Front Treble Speaker Monitoring inactive inactive (ONLY Audi A4 Cabriolet)
  • 0xx?xxx: Sound Characteristic
    • 0 = Sound Characteristic linear
    • 1 = Audi A4 (8E)
    • 2 = Audi A6 (4B)
    • 3 = Audi A4 Cabriolet (8H)
    • 4 = Audi TT (8J)
    • 5 = Audi A3 (8P)
    • 9 = Sound System
  • 0xxx?xx: Telephone/Telematic
    • 1 = Telephone not installed (Remote Feed Voltage for Microphone active)
    • 2 = Base Plate (Temic - Remote Feed Voltage for Microphone inactive)
    • 3 = Base Plate (Cullmann - Remote Feed Voltage for Microphone inactive)
    • 4 = Base Plate (Nokia - Remote Feed Voltage for Microphone inactive)
    • 5 = Telematic Europa (Remote Feed Voltage for Microphone inactive)
    • 6 = Telematic US (Remote Feed Voltage for Microphone inactive)
    • 7 = Base Plate diagnostic capable with Comfort Control
  • 0xxxx?x: Equipment I
    • 1 = Tuner not installed
    • 2 = Digital-Radio installed
    • 3 = Satellite-Radio installed
    • 4 = Satellite and Digital-Radio installed
    • 5 = Analog Input (AUX) installed
    • 7 = Satellite-Radio & Analog Input (AUX) installed
  • 0xxxxx?: Equipment II
    • 1 = TV-Tuner/CD-Changer/Multi-Function Steering Wheel not installed
    • 2 = TV-Tuner installed
    • 3 = CD-Changer installed
    • 4 = TV-Tuner and CD-Changer installed
    • 5 = Multi-Function Steering Wheel installed
    • 6 = TV-Tuner and Multi-Function Steering Wheel installed
    • 7 = CD-Changer and Multi-Function Steering Wheel installed
    • 8 = TV-Tuner and CD-Changer and Multi-Function Steering Wheel installed
Adaptation Channel 001: Tire Circumference The tire circumference is beeing adapted in "mm".
Channel 002: Wheel Pulse The wheel pulse describes the amount of wheel pulses per revolution.
If value 0 is entered the system calibrates automatically itself after several kilometers and inputs a value.
  • 43 = Audi A3 (8P) / Audi TT (8J)
  • 45 = Audi A4 (8E)
Channel 003: Language (Screen)
  • 0 = German
  • 1 = English (UK)
  • 2 = French
  • 3 = Italian
  • 5 = Spanish
  • 6 = Portuguese
  • 7 = English (UK)
Channel 004: Back-Up Camera
  • 0 = Back-Up Camera not installed
  • 2 = Back-Up Camera installed
Channel 005: Speed Threshold (Video Input)
  • 0 = max. 0 kph or 0 mph
  • 1 = max 5 kph (Standard for Europe)
Channel 007: Options Channel 008: Volume Characteristic Channel 010: Region
  • 0 = Europe/North America
  • 1 = Australia/South America
  • 2 = South Africa
Channel 011: Language (Speech Recognition)
  • 0 = German
  • 1 = English
  • 2 = French
  • 3 = Italian
  • 5 = Spanish
Channel 018: Start Screen The start screen setting has to correspond with the control module coding, e.g. a S3 start screen doesn't work with an A4 coding.
  • 0 = Standard Start Screen
  • 1 = Audi S3 Start Screen
  • 2 = Audi S4 Start Screen
  • 3 = Audi RS4 Start Screen
  • 4 = Audi TT Start Screen
  • 5 = Audi R8 Start Screen
Channel 065: Read Test Channel 066: Self Test Channel 067: CD/DVD Drive
  • 000 - Normal/Eject-Button enabled
  • 001 = Eject CD/DVD (will not be saved)
  • 255 = Eject-Button disabled/locked (Anti-Theft-Protection)
Channel 068: Screen Test Values will not be saved, they only act as initiation for each Test Picture.
  • 0 = No Test Picture
  • 1 = Test Picture: Red
  • 2 = Test Picture: Green
  • 3 = Test Picture: Blue
  • 4 = Test Picture: White
  • 5 = Test Picture: Black
  • 6 = Test Picture: Checkerboard
  • 7 = Test Picture: Checkerboard (inverted)
  • 8 = Test Picture: 64 Gray Scales (vertical Bars)
  • 9 = Test Picture: Special
Channel 069: Display Mechanism
  • 000 = Display closed
  • 001 = Display open
  • 200 = Display half open (Obstacle)
  • 255 = Position undefined
Channel 070: Display Brightness
  • 0 = 0% Brightness (Display OFF)
  • 1 = 20% Brightness
  • 2 = 40% Brightness
  • 3 = 60% Brightness
  • 4 = 80% Brightness
  • 5 = 100% Brightness
Channel 099: Transport Mode Only applies to models without Gateway/Diagnostic Interface for Databus.
  • 0 = Transport Mode inactive
  • 1 = Transport Mode active
Channel 111: Reset
  • To perform a system reset/restart save 1 as new value.
Channel 114: FM Frequency
  • Range: 875...1080
Channel 117: Signal Test (Output)
  • 0 = Fader Center & Balance Center
  • 1 = Fader Front & Balance Left
  • 2 = Fader Front & Balance Right
  • 3 = Fader Rear & Balance Left
  • 4 = Fader Rear & Balance Right
Channel 136: Driver Position
  • RNS-E Basic
    • 03226 = Left-Hand-Drive (LHD)
    • 02632 = Right-Hand-Drive (RHD)
  • RNS-E High/US
    • 00005 = Left-Hand-Drive (LHD)
    • 00013 = Right-Hand-Drive (RHD)
Jul 04, 2010 | 2007 Audi TT
My 2001 audi allroad has a navigation plus system. When i put in the pin number, it says pin not connected. How do i fix
My A6 from 2002 has a 6 CD autochanger - the screen does not recognise that the cd's are loaded, saying four of the 6 are empty and not playing either of the others. Indeed the same info comes up on the display even if the cassette is left out. Any ideas?
Mar 18, 2010 | Blaupunkt Car Audio & Video
I change my bettry for Audi A6 and lost Car Radio Code.
Dear SirGreetings I have Audi A6 2001I changed battery and the CD changer & radio are not working.How can I solve this problem please?Thanks
Sep 15, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Error 1 how do i fix (audi tt cdx-t69)
It means that the CD changer is malfunctioning. Mostly happends after condensation, due to it's location near the taillight. Go in the back, clean any moisture, take out the CD, and re-insert it. Problem should be solved. Audi should put this as one of the most common defects between the 99-03 a6
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 12, 2009 | Sony CDX-T69 6-Disc CD Changer
A6 Battery removal
You should check either - www.audiforums.com www.audiworld.com or www.audizine.com, register and search the forums, should be good info. also check under the battery, man audi cars have secondary brackets underneath to hold the battey in place.
Nov 25, 2008 | 2001 Audi A6
How can I find a replacement 6 CD disc changer for my Audi A6 (2005 model) please?
Most of the OEM headunits and changers are made by common radio manufacturers. Visit http://www.crutchfield.com and contact them. They make adapters that will interface an aftermarket changer to your factory system. if you could get me a model number and any other info offf of the radio and the changer I will research adapters and which brands and models of changers will work.
Nov 14, 2008 | 1997 Audi A6
Car Audio & Video Logo
85 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
