Question about Sony Cyber-shot DSC-W50 Digital Camera
Error hello,what should I do to have my camera repaired,if occurs information about turning off and then turning on power.I can browse any photos,but I can't take aby pictures
  • Anonymous Jul 14, 2008
    I have the same problem. No abuse to camera it just started telling me to turn off and then back on. When I do this nothing happens. I cannot do anything else with the camera at this time. Thanks for any response.
  • mel44 Jul 14, 2008
    I have the same problem. It has just started. The lens goes all the way in when the power is shut off but it will not allow me to take any pictures. My issue is that the camera is only about a year and a half old? What a a case of planned obsolesence...I know I am going to hear it is not worth fixing just get a new one!
  • 74 Answers
Switch onwhen lense extends take hold of the end of the lense and twist and pull gently you may hear it click don not force it or make it pop. twist left to right this should solve the problem
Posted on Oct 17, 2008
Cannot import photos off my camera sd card,
I would try a different card in the camera, and format it before using.....if that works then you may have to use some special software to retrieve the photos off the bad card if they are important to you....
Dec 29, 2016 | Cameras
My Sony NEX-3n has a weak magnet that prevents the camera from taking more than one picture at a time,this makes the camera error turn power off then on
You will need to return the camera to Sony for service, they do not sell any parts or repair information to the public. The cost is about $200.00 US
Aug 18, 2016 | Sony Cameras
Nokia N72 Camera problem,Unexpected error occurred. Power off the device and restart
sir my nokia n72 mobile camera unexpected error occurred. power off the device and restrart .please help me
Jul 13, 2012 | Cell Phones
I have an E91-01 error message which will not correct itself after reinitialising. How can I solve this? The camera is a Sony DSC W50. Thanks
Hello and welcome to FixYa!
To solve the error E91-01 error, Please follow the instructions given below:-
  • Turn the camera OFF
  • Remove the battery or the power supply
  • Turn the switch to CAMERA for about 30 sec
  • Turn the switch to OFF
  • Install the battery or power supply
  • Turn the switch to MEMORY
  • Open the LCD cover and press the RESET button ( small inner button )
  • You will be prompt to adjust date/time. Do it
  • Now Take some pictures
Error will be removed, If still occur, Perform the above steps once more, after it if still error prompts then it means that service is required by authorized service and they should change the flash unit, In this case go to authorized SONY Cameras service provider, Your problem will be solved.
I hope this solution helps you
If you have any more Confusion, questions or issue regarding your problem do inform me.
Thank you for using FixYa!
May 14, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
Error code 2881
Found error in image file, Error Occurred, error 0901, 572, 2881
The camera says found error in image file, repair data now. When you press yes it says "Error occurred. Please replace disc." or use ac adapter/charger, turn off power. It won't let you go to Disc Navigation to finalize it. While recording video on DVD-R media the battery power may have failed and camera shut off. When turned on the message shown on the lcd is Found error in image file, Error Occurred, error 0901.
Regards.
Jan 12, 2011 | Hitachi DZ-MV580E DVD Camcorder
Pentax Optio A40 - switches on but screen is white with a purple smudge on it . Please help. Is it worth repairing ? Thanks Carol
Hello
OK, well, this sounds to me like a blown CCD. Try taking a photo, if the photo turns out the same, it is most probably a CCD.
You can take the camera to your nearest repair shop, they will be able to inform you on the exact repairing cost.
Hope this can steer you in the right direction.
Kind regards
Andrea
Aug 30, 2010 | Cameras
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
Error code messages in the status panel of the Fun! Digital 320 camera.
The following is a listing of the error codes you might see on the status panel of the PhotoMAX Fun! Digital 320 camera: 1.FL - Photo memory is full. You cannot take more photos. Download and then erase the photos in your camera. 2.FE - Flash memory error. A camera hardware error occurred. This can happen when the power is shut off before a photo is completely stored in the camera. Do not shut off the power until the green light comes back on steady after you take a photo. 3.bE - Hardware problem. Turn the power switch on and off and see if the error message disappears. If the error message persists, the camera may need to be replaced. 4.Lo - Battery low. Replace the camera battery as soon as possible. If you continue to use the camera, picture quality will be poor. 5.LL - Low light condition. The camera does not have enough light to take a good photo. Improve the subject lighting if possible. Example: When taking indoor photos, add additional room lighting.
Sep 21, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
