I put a new Alt. and battery in drive it to work, on the way home the head lights dim then death. What could be draining my battery?
Hey
u need to check your battery power
turn off everything (car not running) and install an ammeter
(use a multimeter which will give you range select capability) in
series with a battery lead and then make sure everything is turned off
again.. Read the meter. If there is a current drain, the meter will
show it. Then you can start removing fuses one at a time to determine
what circuit is causing the current drain. Inserting a meter will also
resolve the question of whether it is a real drain or some anomaly in
the battery.good luck.
