I think the problem didn't come from the television. Maybe the disc is too hard to play, this usually happen when we play an original CD or DVD. Or your CD/DVD player already broken so it can't spin the disc.
is it a burned disk? if so your dvd player might not be able to play that type of dvd... i know sometimes also scratched ones won't play at all as well... of course also make sure everything is plugged in correctly and if it does this with more different dvds then there's something wrong with the player itself... which i hope is not the case as those are very difficult to fix yourself
double check if it really is a dvd and not a vcd, the latest dvd players only play real dvd's so not the ones you make at home by downloading movies and burning them on empty cd's
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
Comments:
To set Region code to 0 on a Teac PL-D2000 DVD System to enable play of any region
Ensure TV monitor is on so and set to display DVD.
1. Turn system completely off.
2. Turn on system.
3. Open tray.
4. Using remote press and hold the return button.
5. While holding the RETURN button, press and hold the DISPLAY button.
6. You will see something like this displayed on screen: VER 1006 TE 3210
7. Release DISPLAY and RETURN buttons simultaneously.
8. Press the ANGLE button. You will see WRITING REGION ID displayed.
You can now play DVDs from any region.
0
If you are playing STANDARD CD or regular DVD that you have purchase and you are having this problem,your dvd player is malfunction;however,if you are playing DVD burner disc or a different dvd region disc(we are region 1 in U.S.) that is no going to work.Same thing for your CD burner disc,it might not work. If you are using a rental dvd disc,check and see if there is scratches?If so,try to get one without that many scratches! Joe
