Question about RCA F36650 36" TV
Color on the picture is dark
The color on my RCA F36650 36: TV is dark. When I try to hit the menu button a black box come up on the screen.
  • pattyburk Jul 18, 2008
    We unplugged the tv to move some things and when we plugged it back in the screen was very dark and we can't figure out how to lighten it back up since the menu box shows up black
    Problem Solver:
  • 5 Answers
You can adjust the brightness on the back of the set which says screen. put a mirror so you can see the screen and slowly turn the screw clockwise until you can see the picture.
Posted on Aug 02, 2008
Color went to black and white
You have it hooked up to Analog TV with your RCA jacks. I had the same problem.
Jul 23, 2010 | RCA F19431 19" TV
My tv needs readjusted (color,focus,etc.)Is there an easy way to do so myself? i got a 1986 45'' RCA projection tv.it started of with just a blury spot across the top but after i messed with it the whole...
First pull back Look for screen and focus block you will have 3 controls ontop for focus and 3 controls below for adjusting screen drive to each Tube R/G/B
turn color off on Menu NOW try to Adjust the red,greenand blue screen drives as close asyou can to a Black and White picture then turn Color back on in Menu also adjust Focus for each Tube Be sure to Clean Top of Tube Lenses of dust&dirt Just in case Post me your Model and Chassis Number it will be on back of TV some RCA Focus&screen drive Block maybe in front of TV if so remove front bottom panel their you will see control box.
Nov 10, 2009 | Televison & Video
There is a large black area in the upper left hand corner of the screen
If it is a square box, it is usually a text box. It can be fixed by turning closed captioning off. Either hit the CC button on the remote until off appears. Or go in to the menu find closed captioning or text and turn off. If it is not a defined box, it could be something inside the tv.
Oct 27, 2009 | RCA Scenium D40W20 40" Rear Projection...
I'm trying to improve the picture- seems to be TOO DARK- tv is 10 yr old ser3 935351541- ihave tried color adj etc
Rca Screen Control These sets have screen control adjustment usually located behind the speaker grill(pops off -velcro or press tabs) and convergence front board. There are 6 contols on a black molded assembly about 31/2"x21/2" square. adjust only the top controls marked "Screen R G B" the bottom ones are focus
Method:
-turn on set and let warm up for 30 min at least
-switch tv to blank unused video input channel
-adjust each control in turn until you see the picture glow (with the corresponding color) and slightly back off the control - repeat for each color - this will increase screen brightness and ballance your color
Hope this helped.
Oct 18, 2009 | RCA P52945 52" Rear Projection Television
Snowy picture with catv 1 mono on screen
is tv making some.. sound...please tell me..
Oct 20, 2008 | RCA TruFlat 27F520T 27" TV
Black bars on top and bottom of screen
It sounds as if you have accidentally entered widescreen mode. Explore the on screen menu to find the widescreen option & switch it back.
Jul 15, 2007 | Mitsubishi CS-35405 TV
Rca p52771at - dark picture
Sounds like a bad screen asy,part number 204809,must use the generic,or you could have weak tubes,if so you may just need to turn up the screen drives,this part is located in the right top of the set with the back removed,if no cracks are present adj. the three marked screen's,turn the color all the way down in your menu and adj. for a black and white picture.
Oct 07, 2006 | RCA P52771AT 52" Rear Projection...
RCA F32649
i dont know this exact model, but i can advice you based on a slightly diffrent model. i hope the solution will be valid for your model as well: TV is digital controlled and have to be adjusted via service menu except the external focus and screen on back of (flyback) high voltage transformer. This is one you can try: Need plastic allen or plastic small flat blade screwdriver to fit these. Focus is top, bottom is the screen that set the overall brightness. Before adjusting, go in menu: press menu once, select picture quality, I think number 4, press 2 for "preset..", press 2 again to select normal. Back out by pressing zero repeatedly. It may ask you to save new settings, select yes. If screen is adjusted too bright, picture look lousy (washed out) the blacks will light up (becomes grey, or visible lines) this means you have actual fault that prevents you to get decent pix, that when it is time to take it in for repair.
Feb 11, 2006 | RCA F32649 32" TV
RCA F36650 36" TV Logo
105 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
