Ovens Logo
Posted on Jan 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Leisure Alto fan oven element to fit and instead of screws it looks pins/rivets how do I change it
Carl Kay
Level 3:
  • Master 827 Answers
  • Posted on Jan 05, 2011
Carl Kay
Master
Level 3:
Answers
827
Questions
Helped
195546
Points
2364
Drill out the rivets and replace with screws.. you may need a right angle drill or right angle drill adapter to fit the drill in there. Always take care and be sure to FIRST cut off ALL power to the unit and give it a good once over with your eyes to determine where the drill bit would follow through to prior to drilling - just to be sure you are not going to hit any other critical component...
Leisure CMTF95C left main oven doesn't heat up
call a local repair service they can test it and fix , unless it is really Old
Sep 21, 2021 • Ovens
tip
How to diagnose, fit and change a Belling fan oven element
If your fan oven is not heating up properly the Fan Oven Element for your Cooker is usual culprit. Fitting an oven element is generally very easy, as demonstrated by The Apart4u video on How to change repair and replace your fan oven element:this fan oven element can usually be changed without taking the appliance out of situ. Belling Elements
tip
Belling Elements
3helpful
2answers
Flavel milano e60 how to fit new fan oven element that is riveted
That is complete RUBBISH the screws are accessible from the rear of the oven. At the back remove the screws holding the plate and you will see the element housing. Remove the two screws and the spade connections. Get someone to hold the new element in place for you and attached the screws. Fiddly job so be patient. Connect the spade connections and replace all plates front and rear. Should be the job!!! Someone hold the element in the cooker whilst someone connects at the back. Whatever you do, DON'T TAKE A DRILL TO YOUR COOKER!!
Dec 13, 2012 • Ovens
tip
tip
2helpful
Leisure levc66x - bang from fan oven blew tripswitch - fan operating but no heat - top oven ok - 18 month old unit
It appears that the ring element for the oven has burnt out and will need replacing.
Hope this helped.
May 13, 2010 • Ovens
1helpful
2answers
Belling Synergie
NEED NEW FAN OVEN ELEMENT THAT CAN BE FOUND HERE
You need Element code AB20 on link below
http://cookerandovenelement.co.uk/bellingfanovenelement.html
element is located on back wall of oven you need to pull oven oven to remove the element element is held by two nuts from back and i screw from front
tip
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
