Question about Microsoft Xbox 360 Console
Disk drive will not open
It seems as if here lately the disk drive has problems opening , right now its stuck and we cant get it open
  • ozono Jul 11, 2008
    Thank you so much it did the trick!!!!!
    Problem Solver:
  • 14 Answers
When I got this problem I put my xbox on its side then straight up and it opened. If You keep a game in it The drive should stay able to open.This is what worked for me.
Posted on Jul 10, 2008
Open stuck cd drive
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard.
If this does not fix the problem it might be a registry problem
"you only need to do the following"
if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computerOpen My Computer and check to see if your CD or DVD drives have returned.
You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Oct 27, 2013 | Computers & Internet
Cd stuck in emachine and there's no pin hole
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope it helps
Jun 15, 2012 | E-Machines emachines (emachinees) CD-ROM...
My LG usb flash drive model lge-um5(b) is write protected. i cant open the file in my usb flash drive. i cant reformat it. please help me. thanx
Format your pen drive through computer management.
It will solve your problem
1. Go to desk top and right click on your my computer icon.
2. You will get one option called Manage.
3. Click on that , it will open a console.
4. Then click on disk management .
5. you will see your hard disk partition and pendrive.
6. Right click on your pendrive and format it.
Hope it will help you .
Thanks for using FixYa.
May 18, 2011 | Computers & Internet
My dvd drive is not recognizing any cd or dvd. it is since 1 and 1/2 months. even i cannot erite any dvd and cd. plz sir tell me some solution for it.
Make sure the light on the drive is coming on when you insert a disk. I am assuming that drive tray opens and closes when you press the button and that you are not opening the tray manually or forcing it open. Try to spray some compressed air into the drive with the tray open incase anything is interferring with the laser. Has anyone been inside the computer lately that may have disconnected a cable from the back of the drive? Not to be funny, but make sure you are inserting the disk right side up. You may just have to buy a new drive.
Mar 08, 2011 | HP Computers & Internet
I cant open my dvd drive. how do i do that
If you just want to get it open to retreive a disk, you can pop it open with a straightened out paper clip.
Look closely at the face of the DvD player. You should see a small hole usually off to one side slightly. Push the straight paper clip into the hole, you may have to push firmly.
This is the emergency open method. It will allow you to retrieve a stuck disk. It will not fix a broken player.
It's likely you may need to replace the device.
Feb 26, 2011 | Gateway SX2800-01 PC Desktop
Tray wont open and tuner seems not to work
Disc tray belt that opens door has too much slack and need to be replaced,$2 item,belt size 1.9.To get tray open use your knuckles and tap on TOP of cabinet just above disc door while pushing open button.When open you will see the tiny belt that operates door to the right,use twizzers to remove an replace.Make sure new belt is seated properly in tracks if not tray won't move.
Jul 30, 2009 | iLO DVDR04
Problem installing,deluxe version 7,greeting card
insert disk
click on MYCOMPUTER and then RIGHT-CLICK on the drive and then click or EXPLORE
This should open a folder for the disk. somewhere in there should be an EXE file with SETUP in the title.
if the folder doesn't display the contents you may have a bad disk
if it does and you cant find a setup program let me know.
is this the only disk you have had trouble with lately?
Dec 26, 2008 | Nova Development Art Explosion Greeting...
Cannot open the disk drive.
It happens when you stop using your drive
use pins and insert in small hole present above the LED[light]
Dec 09, 2008 | E-Machines emachines (emachinees) CD-ROM...
PSP cant load games
Maybe needs the laser lens cleaning.
You'd be surprised how much dust get sucked in.
You can do it yourself if you are careful.
All you need to do is with the PSP facing you as normal open the drive door at the back, look to the right hand side inside the PSP for a little round shiny lens.
Then carefully wipe a coton bud across the surface. No pressure is needed. Sometimes thats all it needs.
There's a picture of one taken out of the PSP so you can see it more clearly. The bottom of the picture is the top of the drive where you insert the disks. The bit that looks like a record is the motor turntable that spins the disk. You should see that in the middle of the drive when you open the door. http://i48.photobucket.com/albums/f217/StuartB4/PSPLaserAssembly.jpg
Hope it helps.
Mar 06, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Console Logo
29 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Mike Neath
Mike Neath
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
