Question about Xerox Office Equipment & Supplies
Hello, i have a xerox phaser 7300 printer and it will not print the black. i have changed the toner and the cradle. i have swapped the black and yellow led's and the yellow still prints but the black doesn't.i have checked the transfer belt and it looks alright, there appears no obstructions anywhere. if you have any suggestions that would be great, thanks, pete
    President:
  • 2,072 Answers
It sounds like the drive clutch or motor to the black housing is not running, or the drive is not transfering to that area.
I would check to see if there is a broken gear in the machine, look where the drives are on the cartridge and trace where the drive in the machine would be located based on that.
If a motor would be bad, the machine would fault out, a clutch could be slipping and not allowing drive, that would not fault out, just not produce black.
Posted on Jul 10, 2008
I have a Xerox phaser 7300 that keeps telling me to install or reseat the black cartridge
It is slightly unusual for it to be the black toner cartridge (usually cyan or magenta) but this issue is quite common on the 7300. You can find a lot of information about this here.
Dec 15, 2010 | Xerox Phaser 7300DN Laser Printer
Out of magenta toner, but need to print in black
normally most printers when you select properties and advance you can select the quality of printing there you can select grayscale instead of color that will do it
steps
click start printers right click properties for pinter select advance change the settings. print a test page will come only black if not repeat steps.
Jul 26, 2010 | Xerox Phaser 7300DN Laser Printer
The "Reseat Toner Cartridge" message keeps appearing, if I open and close the lid the message goes away and it seems to print normally.
There is a firmware issue that causes that problem.
You can download it from the Xerox.com site and upgrade your machine. The instructions on doing that upgrade are also on the site.
Go to Xerox.com. Then click Suport and Drivers, then enter 7300, then to drivers and downloads and scroll down to the firmware update.
Feb 10, 2010 | Xerox Phaser 7300DN Laser Printer
Phaser 7300 - one color fading on diagnostics page
Are you using third party toner? That is one thing that causes that problem. Use only xerox toner.
The other thing is that your image unit could have come defected, if it was brand new. Try changing the image unit and that should fix that problem. Good luck. 016-1993-00 image unit & toner 016-1977-00
Oct 02, 2009 | Xerox Phaser 7300DN Laser Printer
How do I clean a toner spill off my transfer unit on a phaser 7300?
Hello sir; You can use vacuum cleaner for office equipment use .
Aug 28, 2009 | Xerox Phaser 7300DN Laser Printer
Invalid Black Toner Xerox Phaser 6110 MFP
reload the driver again and if it persists, change the toner
Jun 23, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
False reading of toner cart status
Sounds to me like you actually have the wrong part number. There are more than one cartridge for the Xerox printers, They have different chips on them. One is for billable accounts, one or more than one for accounts that pay for prints. There also was as i remember a spring type clip they left off some cartridges.
So with what you have tried and the old cartridges work fine, strongly suspect bad carridges.
Dec 01, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 6125 Color Printer
I called Xerox and it seems that it's because the imaging unit is defective. They are seeding me one free of charge. Hope you can do the same...
Sep 20, 2008 | Xerox Phaser 6125 Laser Printer
Phaser 6250 black toner is super light
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=842,E=0000000000019251353,K=6024,Sxi=13,Case=obj(19377)
Click on Knowledge base from this site , then in the search box enter poor black quality. Look under black is faded or missing
Apr 08, 2008 | Xerox Phaser 6250N Printer
Specific PDF Document/Specific Print Area Black Toner Not Fusing And Flakes Off
Without a doubt you have a problem with the fuser.
What that is caused from is buildup over time of ink on the heat roller. The teflon coating wears some and the ink sticks to the aluminum instead of pealing off onto the paper.
You then do not get enough heat or perssure to "fuse" the image into the paper.
Replacine the fuser will correct the problem.
Feb 03, 2008 | Xerox Phaser 7300DN Laser Printer
73 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
