My computer advent7113 has a blue screen saying system fatal error the system has been shut down i have tried the f8 key not working what can i do
    Scholar:
  • 119 Answers
You need to read the blue screen it will tell you what is causing the problem with the. most often this is caused by faulty RAM. but should you not be able to find the fault try re-installing your operating system. that in most cases will solve the problem, unless the problem is hardware related.
Posted on Jul 10, 2008
Blue screen death
All your data is probably OK. The best way to access it is to remove the disk and put it into another computer. You should then be able to find the data on the disk, although it will have a different drive letter. Next time make sure your keep back-ups of all your important data.
Aug 20, 2017 | Fujitsu Siemens Computers & Internet
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN on a dell latitude D505 laptop
try to boot to safe mode using F8 key on boot and then recover system or reinstall OS
Nov 13, 2012 | Dell Latitude D505 Notebook
Blue screen fatal system error c000026c
this is indicative of a driver problem, start tapping the f8 key @ boot and then boot the pc into safe mode with networking. once there, either try and do a system restore to before it failed, or simply go to device manager and uninstall any drivers you recently updated. if none of that helps after a reboot, you could always go nuts and uninstall all your device drivers, and then reboot and reinstall them one at a time until you find the culprit.
May 14, 2012 | Dell Computers & Internet
Sir my pc has automatically restart and does not worked proprely they can give the fatal error plzz helpp me
Are you getting a Blue Screen error and can't read it because the computer keeps restarting?
If So, turn off the computer, then turn it on and immediately start hitting the F8 key repeatedly until you see Safe Mode. Scroll down past safe mode and you will see an option to Disable Automatic Restart. The next time you boot up you will be able to see the error message.
If it is a Blue Screen Of Death (BSOD) error message, you might need a system disc.
Mar 26, 2012 | Dell OptiPlex GX620 PC Desktop
Compaq Preario V5245eu cant get past scrolling xp window just restarts and doesn'r get anywhere have had a c000021a fatal error warning- help please Rodger
If you attempt to install a piece of hardware or software on your PC computer that is incompatible with your system, you may see a blue screen with a C000021a fatal error warning. The easiest way to recover the Windows operating system from this type of error is to restore your computer to a previously working state.
1.Press the "F8" key on your keyboard when prompted during the boot process.
2.Use the up-and-down arrow keys to highlight the "Last Known Good Configuration" option. Then hit "Enter.
3.Use the up-and-down arrow keys to highlight the operating system version that you wish to boot up to, and then hit "Enter" again. The system will now restart to the last working version of your operating system, which will eliminate the C000021a fatal error.
Hope this helps
Mar 13, 2010 | Computers & Internet
My computer starts to boot then once it is completed the a message comes up saying there is an error and then a blue screen comes up and reboots itself. THis continues and does not stop
When starting up, press the F8 key to catch the Boot Menu. Select the option to disable automatic restart on system failure. Boot and when it fails the Blue Screen will remain for you. Look near the top and see what file has been identified as the failure i.e. NV4_disp.dll. (Google the file name to see what program or hardware the failed file is associated with) Press and Hold the power button to shut down. Turn the computer back on and press the F8 key again to catch the Boot menu, and select Safe mode. If allowed into Safe Mode, try to go into Device Manager and either disable the failing device, or remove the associated program. If this doesn't work you can try to do a system restore to a date before this error started to appear. If you post back the file causing the blue screen, I can instruct you further.
Jan 10, 2010 | Fujitsu Computers & Internet
Unable to get into safe mode
hi there !
-try t drain everything out of the computer first; remove the power adapter then remove the battery; after 1 minute try again; if problem persists run diagnostics
--while the computer is off, press and hld the "Fn" key then press the power button at the same time to start the test; note down error message then consult manufacturer for the code obtained. if no errors found it is a windows problem; you need to reinstall windows on the computer
cheers!
Sep 28, 2009 | Dell Vostro 1700 Notebook
The computer starts then shuts down.
Try booting up the computer pressing whatever key the Dell needs to boot into BIOS (F10, Delete key, F1...pay attention to the screen) and leave the computer on for about 15min. See if it cuts off then. If it does its more than likely your power supply. If it doesn't then its not hardware related.
Mar 12, 2009 | Computers & Internet
HP Pavillion dv9000 fatal error
On the windows boot screen you should be getting choices for safe mode, safe mode with networking, etc ...
Select "Disable automatic restart on system failure'
And let me know what error message(s) you have ... write it all down
Jan 14, 2009 | HP Pavilion dv9000z Notebook
I keep getting a blue screen that says fatal system error. My computer is a toshiba satellite x205-s7483. Th computer wont start up and takes forever but when it does the computer runs slower, freezes or...
it is a fatal error mostly occured in windows like xp. it is also the prevention of disturbing with the memory.
we have some tips to recover from there. first you have try to boot as last known good configuration option in the windows startup option. (you press F8 key, when the computer boots up).
if it is not working, try to boot in safe mode.
if it is also not possible, you have to go with your xp cd or operating system cd. first boot with operating system cd and go for the repair option to recover your operationg system.
Jul 21, 2008 | Toshiba Computers & Internet
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
