Question about LG WM-2277HW Front Load Washer
Won't spin My washer drum seems to be "disconnected." It makes the noise like it should be spinning, but the drum doesn't spin. When looking at the drum it looks like it isn't sitting correctly. Thanks!
  • Richard Lew May 11, 2010
    Is there any error codes displaying??  Can you turn the drum by hand??  Does it feel hard to turn??
We had it checked out and it was going to cost over $500 to fix. Thanks!
Posted on Jul 25, 2008
I have a Whirlpool Gold washer (MOD# GSQ9669LW0). The washer makes a grinding noise below when in operation. Spins when agitating, but not in rinse mode. Water still pumps out in final spin.
This machine can get items stuck in the drum, the bearings can go bad etc. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/38-5-620929-/Whirlpool-Washer-won-t-spin-GSQ9669LW0.
Oct 16, 2017 | Whirlpool Washing Machines
Whining noise from kenmore elite washing machine during spin cycle
it is poss. the bearings are going. if you can spin the drum by hand and it makes the noise it is the rear bearing...
May 06, 2014 | Kenmore Washing Machines
My lg washer won't let water in on all cycles except rinse and spin and then it doesn't spin properly
Check the electrovalve for the supply of the water and the belt that runs the cylinder of the washer with the electric motor.
Jun 06, 2012 | Washing Machines
My fridgedaire front loader washing machine has been making weird noises when it spins or washes, making sounds like there is loose metal inside somewhere rubbing and clanking around. As of last night...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 13, 2011 | Frigidaire Washing Machines
Hard bang on spin with my frigidaire gallery frontload washer
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 15, 2010 | Frigidaire GLTF1040A Front Load Washer
Loose washer drum, load noise on spin cycle
your basket hub is stripped and to gain has a specific tool to remove and not destroy the locking nut for basket the agitor and items need to be removed it may be best to call a tech in your area
Sep 01, 2009 | Kenmore Washing Machines
Kenmore front load washer #44072 drum banging noise
2 possible issues with your washer.
1 or both the support shocks or springs have broken
the drum would look off center even when empty
or rear bearring has worn out.
this is a very common problem with the fridgidaire washer... (this kenmore is a frigidaire model)
problem is caused by very hard water (well water) or improper use of detergent. this machine uses a High efficency type detergent, marked by "HE" on the detergent container
May 27, 2009 | Kenmore 44072 Front Load Washer
Samsung silver care washer
There may be a problem with the bearings that drive the drum unit. Best to call a master to look.
Nov 15, 2017 | Samsung WF337AA Front Load Washer
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
LG WM-2277HW Front Load Washer Logo
118 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
