Question about Dometic Rooftop RV Air Conditioner
A/C switching to heat
Hi, I have a 630516 unit that will run for a short period in the A/C mode and then switch to heat. I have checked power to the reversing valve coil and have power to it. Is the problem a weak coil or do I have problems elsewhere?
Jeff
  • mechmagcn Jul 15, 2008
    After extensive troubleshooting, I figured out the problem. The coil on the reversing valve was getting hot and no longer able to hold the valve in the A/C position. After replacing this coil, the unit is working as it should.
    Jeff
I have the same problem, it may cool for 1 min or 5 min then go to heat mode. Once it goes to heat mode only way to reset is to shut the AC down and let it cool. It may or amy not work the next time.
Posted on Jul 14, 2008
Water switch open , heater heats up for short period and cuts out
ensure pump is running at full prime. clean the filter out as well. disconnect both connections from pressure switch in raypack heater. check continuity. if switch opens at any point and you have no flow restrictions then replace the pressure switch
Mar 11, 2014 | Solar Rheem Gas Fired Pool & Spa Heater...
DONT KNOW EXACTLY WHAT IS WRONG. OUR POWER BILL LAST YEAR WAS 211.00 AND KNOW WITH THISE BILL IS 678.00. IT IS H EATING AN 18X23 ROOM. THE SETTING FOR TEMP. IS ON 72 DEGREES. THIS THING HAS RUN OUR BILL UP...
Simple way to pay less bill with big comfort.
Tips for it: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat" Clean indoor and out door periodically ( Once in 4 months) Clean Air filter every fortnightly. Avoid frequent opening of the door where it's air conditioned. Avoid keep closing the doors even a/c is switch off. It helps to cool the room next times in short minutes. Use proper breaker, wiring for your air conditioner plug points. Make sure your elect meter is working properly.Check your Elect meter with 1000watts bulb for one hour. It should consume one unit only. Hope, it's helpful.
Jan 08, 2011 | Heating & Cooling
When turning on my unit in heat mode the system cycles twice and will not come back on. it will call for heat but the burner will not ignite.
To troubleshoot that effectively you will need to have an electric meter handy...
Then when it does not light...
Check for power going to the ignitor usually 120vac...if you have power then the ignitor is bad...
Check for power going to the gas valve 24vac if there is power then the gas vlave is failing...
If there is no power to the gas valve then maybe the ignition control relay is going bad...
Check power on either side of the pressure switch... when inducer is running the switch should be closed...
Basic Furnace or Heating System Troubleshooting
heatman101
Dec 05, 2010 | Heating & Cooling
I have an intertherm rpbmb030k combo a/c and heat. Had frion put in the unit over the summer and a new digital thermostat. Unit has worked great until we needed heat. Unit works great on aux. heat but...
Hi, if the unit had a leak in it, was the leak located and repaired? Did he check the pressures in the unit now? If it switches to the aux mode ( Heat Strips ) is normally caused when your primary unit, compressor and freon are low on charge. I would have that checked.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Dec 03, 2010 | Intertherm P3RA-060K Air Conditioner
When the locked switch is turned on (and the saw is plugged in and the breaker is good), the saw will not run. Also no power to the light. It stopped while I was cutting and now will not run?? help?
I am looking at the Manual now, here are the solutions they suggest.
-Shorted capacitor-have capacitor tested
-Starting switch not operating-have switch replaced
-Loose or broken connections-have wiring checked and repaired
-Burned switch contacts(due to extended hold in periods caused by low line voltage) Have switch replaced and request a voltage check from the power company (thats word for word from the manual)
I hope this helps
Nov 09, 2010 | Craftsman 12 Tilt Head Band Saw Owner...
POWERS OFF BY IT'S SELF
Hello FixYa customer,
There can be different issues in the mechanism or electrical that will cause the unit to shut down. However, since the power is going off completely after the initial plug in I suspect the power supply.
The SMPS, Switch Mode Power Supply has filter components that age due to heat, the voltage output on the filters reduces until the Micro Processor malfunctions and the unit won't stay on. The power supply filters can be changed by an experienced technician for $10-$15.00 in parts plus labor.
Thank you
Apr 23, 2010 | Sony SLV-R1000 S-VHS VCR
GE zoneline heat not working
You need to have some one check the continuity of the thermal fuses at the plug where it plugs into the side of the control box. It's a two pin plastic white plug with black fabric covered wires coming out of the plug, you should have about (0) resistance or maybe 1 ohm. If you have no reading at all you will have to pull the heating coils out. Not a big job but, the unit must be removed from the wall as you have to take off the long top metal plate. Remember you do this only if you have to get to the coils. You can get the the plastic plug with out removing the unit but unplugging the plastic plug this may be a little tough but, you can do it.
Make sure you pull the Power plug out of the unit or out of the wall before testing for continuity.
I hope this helps. I put a picture below. It's the only one I have. On the right of the unit under the control panel there is a metal box you can see the front if it in the picture. Most units have this box on the right side. On the left side of the box are the plugs for heat, fan and Thermal fuses.
There maybe another plug with yellow wires. the plug with the 2 black wires is the one you want. Squeeze the side of the plug to unlock the plug then just pull out and test.
V6boyo
Nov 09, 2008 | GE Zoneline AZ55H07D Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
114 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
