Question about Dell Inspiron 700M Notebook
Laptop does not Boot - Screen Blank -- Fan On
My Dell Inspiron 700 laptop with Windows XP suddenly will not boot up. I have tried a Boot CD which has worked in the past but that is not working either. The DVD drive turns on for short time but it is not reading the disk.
I can hear the fan going so I know it is getting power. I have read that I should try booting in Safe Mode but I am not even getting past the BIOS.
Thanks for any help you might offer on this.
Tom
  • 2 more comments
  • redmen1969 Jul 11, 2008
    I was able to boot the machine. Pressing F12 while also powering up runs a pre-BIOS diagnostic. Once this ran the system came back to life...thanks.
    Tom
  • ikons Aug 08, 2008
    I have IBM R-51 model and i have the same problem that the fans are working but screen wont start up..I tried to boot it in safe mode but still its showing blank scree.Jump start is also not working..Please help me out...
  • farid690 Dec 26, 2008
    my laptop thosiba laptop not running, may data will loss ?, can we recover taht data
    thanks
    farid
  • graffranch Mar 31, 2009
    This is the same problem I am having but the F12 solution has not worked.  Can anyone help me?
    Genius:
  • 2,028 Answers
Sounds like your hard drive may be going out, do a check disc.
Posted on Jul 11, 2008
I want to restore my dell inspirion 1721 to factory settings i try the f8 key option but in the advanced boot options there is no "repair your computer" option. what can or should i do?
Your laptop should of come with a disc to restore it back to the factory setting what windows are you running?There should be a restore point you can go back to
Jan 12, 2013 | Dell Inspiron 1721 Notebook
Dell Inspiron 2650 will not boot to Windows install CD after UBUNTU Linux installed on machine.
have you went onto the BIOS to make sure that the boot options are correct e.g. CD DRIVE 1st priority?
Aug 06, 2012 | Dell Inspiron 2650 Notebook
Factory settings restore on dell inspiron 1525 windows vista
Resetting a Dell Inspiron to the factory settings allows the user to restore the Dell Inspiron to the original operating condition as if it was just taken out of the box. Dell system includes a restore utility called 'Dell Symantec System Restore' to reset or restore your Dell system to factory setting.
Get the step-by-step how to guide..http://technical-support-squad.blogspot.in/2012/08/dell-inspiron-how-to-factory-reset.html
Feb 12, 2012 | Dell Inspiron 1525 Laptop
Laptop won't boot into Windows XP
Did you do an upgrade or new install? Did you check the system requirements first to see if you could upgrade to Vista? This could all play a part in why it does not boot up. I suggest you reinstall windows XP again.
Jul 04, 2009 | Acer Aspire 5610-4648 Notebook
HOW TO INSTALL WINDOWS XP ON DELL LAPTOP
go into bios by pressing F2 - change the boot order so the cd / dvd drive is the first bootable device and use the installation / recovery disc you got with it and boot from the cd and re install or install windows xp.
If you do not have the cd then you either need to find it or contact dell and see if they have another one with a key ( which may be chargeable )
Apr 23, 2009 | Dell Inspiron 1525 Laptop Jet Black
Remove the hard drive, then see if you can boot to the XP CD. If you can, then the Hard DIsk Drive has most likely failed. Reseat the HDD and try booting to CD again. If problem comes back, try a new hard drive.
Mar 31, 2009 | Dell Inspiron 700M Notebook
No bootable devices on my Dell Inspiron 1150
My Laptop Inspiron 2200 With Windows XP only boot with the C drive when I remove the CD-DVD-CD drive. Otherwise ,I am asked to go to Bios to reconfigure the booting order.
The CD-dvd can not be pick-up by Plug and Play .
As a result I can only use the Laptop without the CD-DVD
When I reconnect the DVD it will not boot.
I have inspected every single pin in the DVD and from the Motherboard I can not see any damages
What do you think is the problem?
Mar 09, 2009 | Dell Inspiron 2200 Notebook
Boot problem on inspiron 1150
Try connecting it to an external monitor.
When you do, as soon as you press the power button to turn on the laptop, close the laptop lid - as this forces the laptop to display on an external monitor.
If this works, then it means the laptop screen is bad.
If it doesn't, the most likely cause would be that the laptop video card went bad.
For a while, some older Dell laptops with high-end nVidia graphics cards tended to die suddenly.
Mar 27, 2017 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Blank screen when powered on.
Do you have any CD’s that came with your laptop? If so, look for one that has “Diagnostics and utilities” listed under the “Contents”. To boot from that CD disk, power on your laptop and tap the <F12> key to bring you to the “One time boot menu”. Insert the CD and then select CD/DVD drive and hit <Enter> key. You can also boot from the Windows reinstallation disk. If the computer boots from either CD, then your Operating System is corrupted and needs to be reloaded.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Dec 22, 2008 | Dell Inspiron E1505 Notebook
Dell Inspiron 700M Notebook Logo
410 people viewed this question
Alun Cox
