Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Dryer venting I purchased a condo that has this model of whirpool stacked washer/dryer. The dryer has no apparent venting when I look at the back and top of the dryer. Is this the normal design for this model? I notice that there appears to be a heat vent (not the lint vent) and it has a build up that looks slightly burnt. Any information on this would be appreciated. Thanks
  • bjoyal Jul 11, 2008
    Thanks for the manuals this is helpful.
  • 525 Answers
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
The link below, will take you to the page showing that the dryer may ducted using the side exhaust kit, which is why you are unable to see it. It should be visible on the exterior of the house as a vent hood.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=204&PPStack=1
The burned lint on the heat screen should be cleaned and your dryer interior cleaned to prevent a lint fire. Then the vent should be cleaned to the outside. Below is link that provides pdf. format owner's manual downloads. click on your complete model number and you can download a manual for your combo unit.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=lte5243d&siteCd=WHRCOM
Thank you,
Dave E. (Illeagle)
Posted on Jul 10, 2008
  • 2,336 Answers
Click here to get some literature for your washer/dryer. Pick the exact model you have and check the pdf files.
Kenmore stacked washer-dryer 41794802301 dryer wont start
dryer working washer not for a kenmore 41794802301 washer dryer combo
Apr 18, 2010 | Kenmore Dryers
No heat in dryer. This is a stacked dryer/washer combo. The dryer is electric. The drum turns and timer works but there is no heat in the dryer or exiting the vent. The washing maching beneath the dryer...
The element to heat the dryer has gone out. You removed the back of the dryer to remove lint you will need to remove the back of the dryer again to access the heating element. It is in the lower left or right hand corner (depending on model) and looks like the inside of a toaster oven small thin wires. Take the assembly out (make sure the unit is unplugged always) get the model and serial # and purchase replacement from an appliance parts house.
Good Luck hope this helped you some
Dave
Jan 23, 2010 | Dryers
Can I tie two dryer vents into one vent stack . I have a condo we are remodeling and we added a dryer in one unit. I was wondering if it is legal to tie the dryer into the dryer vent from another condo
I wouldn't think it would pass code anywhere because some of the air flow from your dryer is going to find it's way back down into someone else's dryer and visa versa and if either of them are gas dryers carbon monoxide will come with it so I don't recommend you try it. It also carries lint from one to the other and that creates a fire hazard..
Sep 13, 2009 | Kenmore 63942 Dryer
Separating a washer dryer combo
This is a one piece unit. It does not come apart. Use and appliance hand truck with straps to secure. You will need at least 2 people to get unit out, heavy. I used to deliver appliances.
Jul 03, 2009 | Frigidaire FEX831CS Top Load Stacked...
Takes the dryer over two hours to dry one load of laundry. It appears to be putting out hot air. When I stop it to check the clothes, the clothes are usually really warm yet still wet. This has been going...
You have a venting problem. Some makes of condo size dryers have a lint screen inside the drum at the back. Check and clean. If not then there might be a screen in the wall or the ceiling of the room the dryer is in. Trace the vent from the dryer to the wall or ceiling. There should be a vent fan in the ceiling. Try asking the condo property management if there is an exhaust fan in the wall that needs cleaning.
Jun 21, 2009 | Dryers
Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
May 28, 2009 | Kenmore 43042 Front Load Washer
My dryer is approximately 16 years old. I have just moved into a condo, and found that the dryer takes a lot longer to dry than the one I had in my last condo. It is a Westinghouse stack type dryer. Do you...
It may not be your heating element. Your dryer lint vent pipe out the back of the machine or maybe out the side may be plugged. You have to pull the machine out and clear that pipe or rebuild it out to a soffit vent or static vent if it is in the attic, or out through your crawl space. This will make a huge difference. If that hot air and moisture doesn't get out of the machine it just goes back into your clothes.
Good luck!!
Mar 08, 2009 | Dryers
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
67 people viewed this question
Dan Webster
Dan Webster
Sal De
