Question about Saeco VIA Venezia
Pump not working - Saeco VIA Venezia
  • damianndanic Aug 05, 2008
    I had the same problem the repair shop took10 weeks to get a replacement pump from Saeco in Italy.
    I noticed that the list of parts they changed included
    part number: 01317801 "silicon touch pad + board dlx." this item was $105 AUD.
    My question is does this part even belong on a Saeco Via Venezia?
    It sounds like the electronic push buttons you find on more expensive machines but the VV is very simple.
  • m00tc0w Dec 16, 2008
    I originally got a VV about a year ago and it worked great until one day almost no water would go through the filter, and the espresso that came out was really thin and tasteless. After cleaning the machine, it still didn't work, and we got a replacement from Starbucks. The replacement was working fine until just a few days ago, when I started having the same problem. How do you tell if it's the pump itself that's broken?
  • 515 Answers
Can you start the machine?
If not, then you have to reset the termal on the machine.
You have to take of the top, after that you have to find the termal on the element that have a little pin in the middle and push it.
Posted on Jul 10, 2008
My windshield washer pump does not work ,pumps are working ,and still they do not work,is the fuse # 6 ?, what else could it be
your question is confusing. you say the pump does not work then you say the pumps are working. If the pumps are working then check the washer hose for being plugged as well as the spray nozzles.
Oct 27, 2015 | 2004 Chrysler Pacifica AWD
Is there different fuses for the front and rear.window wash pumps
check to see if you have power to pump with a 12v tester,if so, it may be the connection to the pump gone bad .you can always put the test light on the fuse end and have someone make the pump work to see if that fuse controls both pumps. make sure 12v tester is ground well .Also you may want to take the hose off the end of the pump that goes to the line to the windshield and see if water comes out the pump
Aug 06, 2014 | 2002 Dodge Grand Caravan
Pump not working
need more info does system have power to pump motor? if not check breaker if voltage from breaker check switch if you do have power to the pump motor sounds like bad pump motor
Feb 12, 2014 | Zodiac Pool Systems Pool & Spa
No pressure out of the pump
Check for voltage at pump wires is it 115 or 230. Pump works when motor spins. try to prime pump if motor working
Oct 10, 2012 | Plumbing
The pump is on a timer and last night during a storm the pump stopped working?
Try connecting the pump to the mains and bypassing the timer.
If the pump works then the timer is faulty and needs to be replaced.
If the pump does not work then the pump motor is faulty,
Jul 20, 2012 | Pentair Pool & Spa
My 912-005 sump pump will not kick on. when plugged in it hums like it wants to work. We tool the cover off as i expected top see a float but we cant see it. Have never dealt with a pump before. ...
When a pump hums instead of working, there are two possible things.
1) Something stuck inside pump impeller. See if there is rust or debris. Move the impeller and see if it rotates freely. Unplug electrical device before working on it.
2) The pump winding has gone bad and pump will never work again.
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
For a price, expert works with you while you work on pump or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 01, 2011 | Zoeller E140 Iron Nonautomatic ...
Pump and filter work fine. After shut down, pump
check for leak on intake union or pump top seal if ok bad seals in pump replace
May 23, 2010 | Sta Rite Pool & Spa
Filter pump will not work
take a pliers and turn shaft with pump off if it turns, turn pump on they tend to stick from not being used
Jun 08, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Yamaha 1987 FZX 750 fuel pump problem. I have new fuel pump and fuel pump relay but the pump is still not working. The pump worked for a short while but then it stopped before even all carburators were...
Most pumps like this work on pressure drop. When the floats open the pump loses resistance pressure and resumes pumping until it feels pressure again.
May 19, 2009 | 1987 Yamaha FZX 750
Saeco VIA Venezia Logo
150 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
