Question about Epson AcuLaser C3000 Printer
Papaer will not feed
We have an Epson Aculaser C3000. The printer regularly shows paper jam in the display. The sheet will have come about half way through the print path. The noise the printer makes before it jams is distinctive - a high pitched whine.
Paper is good quality - in between jams it prints fine
  • 1 more comment
  • MarkoP Oct 28, 2008
    We have the same problem with C3000.
    Can anyone please help?
    Mane
  • itsconsult Nov 18, 2008
    Hi We have tried the fix on epsons web site which appears to have solved the problem - or is thrre something else to be done
  • Anonymous Mar 04, 2009
    Inky,
    I can't find this firmware fix anywhere, and the Epson UK support site has been down for the past few days. Are you able to send me the link to this if possible?.My email address is billboy999@gmail.com
    Thanks in anticipation
    Bill
    Problem Solver:
  • 10 Answers
Paper jam on Aculaser C4100.
First solution: (gives high pitched whine when starting to print) -> do firmware upgrade
Second solution: (printer stops when paper is in the fuser) -> fusers get too dry prematurely. Replace or if you are handy: lubricate cloth inside of fuser roll with high temperature silicone compound. (i.e. CHEMPLEX 710 )
Posted on Feb 06, 2012
Epson have released a firmware update on their support website for this problem. This appears to have solved the problem
Posted on Nov 18, 2008
  • Epson Master
  • 691 Answers
High ITConsult And MarkoP
The high pitched whine and the paper stopping just before the fuser (the hot) unit is a known issue on the C3000 and C4100. If you are still searching for the solution to this issue, let me know, as I now have a working fix for the problem.
Reply to this post for further info.
Paper jams regularly on Epson Aculaser C3000. Had to update firmware a while ago. Now that problem has returned I tried to run the latest update (NVMUpdate_10106.exe) but get error message that dll...
I had the same problem. Update program is most likely not designed for Windows 7. I've launched it in Windows XP (SP3) compatibility mode and it did the work just fine.
Oct 14, 2010 | Epson AcuLaser C3000 Printer
Hi. Epson C3000 aculaser. It is ghosting on only on black at a pitch of +/-62mm and also printing horizontal black smudges across both side of the paper at a pitch of +/- 25mm. I have totally cleaned the...
Hi Colin.
I just have had the same problem with my Aculaser C4200.
I may have found a way to solve you problem.
Just print 10 blank (without anything), and after that i took all toner's, the fuser etc. and put it back again. Printed 10 more blank pages, and printed over 200 pages with lot of tekst and colour (think that 50 pages could do it).
After 2 days everything is still ok for me.
Sep 30, 2010 | Epson AcuLaser C3000 Printer
Epson Aculaser CX11N /11NF. Paper jam error will...
this could be due to the sensor at behind of the printer.. you should be able to see it once you open cover E.. it's very delicate plastic and normally when you clear the paper , you might accidently damage it.. you will need to open the read feed assy to fix it.. 4 screws and you should be able to remove it.. but first remove the E cover but slightly forcing the lower left hidge.. use a test pen...
May 20, 2010 | Office Equipment & Supplies
When trying to print the printer pulls in more than 1 sheet of paper causing a jam in e.ta
just folowe the steps
1. 1
Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
2. Step 2
Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
3. Step 3
Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
4. Step 4
Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
5. Step 5
Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Step 6
Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
7. Step 7
Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Apr 21, 2010 | Epson Aculaser C1100 Printer
Rollers will not feed the paper all the way
<a href="http://files.support.epson.com/pdf/cx11n_/cx11n_pg.pdf" >Here is users guide. Click on related documentation for cleaning rollers.</a>
Nov 27, 2009 | Epson ACULASER CX11NF All-In-One Printer
Epson cx11nf paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Epson ACULASER CX11NF All-In-One Printer
Printer error reads 'Paper Out MP CTM'
Sounds like the document that is being sent to the printer, or the one if pending prints are present, has a page size set to other than what the printer has its set to for the tray feed (or tray feed is set wrong), so it is defaulting to the Manual Feed for insertion of correct medium CTM (not sure if int. but thats maybe a country thing we use A4, ENV and B5 mainly
Dec 01, 2008 | Epson AcuLaser C3000 Printer
Paper Jam at A but nothing there
If you clear the jam and close the machine up again, does the print job eventually print OK. You may have to clear the jam several times before the machine prints it successfully. After the first successful print, does the machine then print ok, until the next time it is left idle for some time? If this is the case, I have a fix for you
Nov 07, 2008 | Epson AcuLaser C3000 Printer
How to fix paper jam Epson CX3650?
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
CREDITS: nanicool
IF YOU DONT GET FIXED WITH THIS THEN PLEASE REPLY BACK.
I SHALL BE GLAD TO HELP YOU WITH YOUR PROBLEMS.
THANK YOU
REGARDS
SWEET RASCAL
Jun 28, 2008 | Epson AcuLaser C3000 Printer
My EPSON Aculaser C3000 is ghosting
Could be any of the following:
* Bad toner - try a different toner
* Unsuitable paper - try a different paper
* wrong software drivers - download the latest drivers for your operating system from the manufacturer's site.
Jan 04, 2008 | Epson AcuLaser C3000 Printer
Epson AcuLaser C3000 Printer Logo
678 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
