Echo effect when viewing movies/tv
What can cause this? I have Comcast DVR with HDMI to TV; DVD/recorder with HDMI to TV; optical from DVD to receiver; optical from Comcast DVR to receiver.
I am considering re-configuring it this way: HDMI from Comcast DVR to receiver; HDMI from DVD/Recorder to receiver; and HDMI out from receiver to TV. Would that make a difference? Do I still need optical and, if so, where? Thanks.
    Novelist:
    Scholar:
  • 100 Answers
Salutations robert42,
Usually echo effects could be the cause of some type of simulated surround or digital processing effects. Its more noticeable with some television broadcasts then others. I would try and deactivate any processing effects and see if this improves your experience.
Hope this helps.
Jon
Go Ahead. Use Us.
Posted on Jul 28, 2008
How do you connect dvd dr420 to dish hd reciver with dvr to give me the capabilityto record from my dvr to my dvd dr420? do you have a phone number? how much does it cost to join fixya?
Connect to the component outputs on the back of the dish receiver. This is the output for TV1. Then conncect the ouput of the dvd dr420 to your TV. I am using the HDMI output on the dr420 to connect to an HDMI port on my tv. This results in a 1080p picture on the TV which is sharper than the 1080i from the dish receiver's HDMI cable. My Sony TV has multipe HDMI ports so I can choose betweeen these 2 inputs and can see the differance since Dish only sends 1080p on it's pay for view channels.
Jun 14, 2010 | Toshiba DR420 DVD Recorder
I have a Philips DVDR 3575H. using Comcast's
Try this set up-
Use an RCA audio/video cable for this set up (Yellow/Red/White).
Connect from the Video out (Yellow) connection on the back of the cable box to the Video in on the back of the DVR.
Connect the audio (Red/White) cables from audio out connection on the back of the cable box to the "Audio in" on the back of the DVR.
This should still get you a decent picture but not a true HD picture for your recordings.
When you set the timer to record set it to record either E1 or E2 depending on which input you connected the cable box to and ensure that the cable box is tuned to the channel you wish to record.
*** NOTE: If you keep the HDMI cable connected as you have for the cable box and watch normal TV through the HDMI input on the TV you will get HD programming for your general viewing but still have the option to record with the DVR at a lower quality. ***
Good Luck and please rate this solution....
Jan 07, 2010 | Philips DVDR3575H/37
Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Mar 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Jan 24, 2009 | Onkyo Audio Players & Recorders
Having problems with HDMI connection from COMCAST Motarola HD Dual TUNER DVR HDMI DCH6416 to Panosonic Home Theater system SA-PT660 to AKAI LCD HDTV. There is only one HDMI Output on the COMCAST box; one...
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
How to Hook up HDMI from Comcast Motarola Cable Box
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Can't record from my digital cable tv to my sylvania dvd/vcr ..........
Depending on the unit your going to need to check the back of the DVR for video out ports... My DVR has VID/HDMI/VCR/1394/SaTa and IR ports I use the VCR out to record with... because on my DVR I can say "Play this movie... now record to VCR and it will only play the movie on those VCR ports not on my TV so all I gotta do is hit record on my VCR... As long as you have audio/video jacks on the VCR. Then even some have it blocked so you can't do that... depends on model. So try recording on the VCR using the video ports instead of the COAX cable.
May 05, 2008 | Televison & Video
Need diagram to connect Motorola DVR, Panasonic DMR-E recorder, A/V Receiver, and HDTV
Your not going to be able to connect in series (not sure if thats your goal) since your limited by the type of connections you can use. Your receiver is going to have to be switched depeneding on what source you want to listen too. DVR, DVD, etc. HDMI is going to important for your TV connection. Radio Shack has cheap HDMI cables.
So... connect HDMI from DVR to HDTV this will give you sound and picture to TV. Connect DVR optical or coaxial ( RCA if you dont care about surround) to Receiver to give you DVR sound thru Receiver input.
Connect DVD to receiver via optical/coaxial/rca for DVD sound thru receiver (again RCA is not recommended for surround).
Connect Component video to HDTV(or HDMI if TV has second HDMI input) to give you video from DVD.
Connect Yellow video or S-video from DVR to DVD recorder input to allow recording from DVR. Also connect red/white audio to (same) DVD input.
That should cover it.
Apr 09, 2008 | Arris DCT2608
158 people viewed this question
 Grubhead
Grubhead
