Question about Whirlpool 11.8 cu. ft. / 334 liter Upright Freezer EV120FXKQ
Freezer frosting up
What do i need to do to cure this problem?
I need more information. If this is a frost free freezer with an internal fan I need to know what the freezer temp is. If a manuel defrost it is supposed to frost up. You defrost it 2 - 3 times a year when the frost builds up over 3/4 inch. If it frosts up faster than this check to see if the door is sealing all the way around. There should be no gaps or cracks in the gasket.
Posted on Jul 11, 2008
How do you make a freezer frost free?
Frost free means that the evaporator coil will not accumulate a thick layer of frost. It will not prevent frost from accumulating on the walls of the freezer. To slow down the amount of frost build up inside the freezer, do not keep the freezer door open for any longer than necessary. The freezer door seal may be defective. This would allow moisture in that would freeze on the inside walls. A heater with timed intervals to come on is one way for a frost free feature. But this will not work for frost build up on the inside walls of the freezer. It would only melt the frost and then it would refreeze again.
Aug 31, 2015 | Frost Freezers
Our Frigidaire frost frost free upright freezer from day one has frost build up on the food inside the packages. The frost is not a problem in the freezer itself, but on the food. Freezer burn occur
Hi Dale Dibb, thank you for your inquiry!
I understand that the food inside of your Frigidaire freezer is getting frost on the inside of the packages. I would recommend turning the temperature up inside of your freezer. Additionally moisture inside of the package would cause frost to develop on the inside of the food packages.
Please assure that all possible moisture has been removed out of the food packages prior to placing the items inside of the freezer. If there is anything else that I can help you with, please feel free to reconnect! -Matt
Sep 30, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My frost free FZA30 has a build up of ice on the bottom shelf. Is there a cure?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 21, 2011 | Hotpoint Freezers
MY FREZER HAS FROST AROUND THE DOOR AND MOLD IS GROWING AROUND IT
You need to replace the door gasket. It's leaking air causing the frost.
May 04, 2011 | Whirlpool Freezers
There is frost around the top of my Holiday manual defrost chest freezer freezer - does the seal need to be reparced
if the frost is just around the top seal area then YES.but if the frost goes further down then the whole unit needs a full defrost (NO scrapers/hot water/steam/or any other "help")use car de icer...and dry thoroughly.also, if too full, it will frost up around the top.
Aug 22, 2010 | Freezers
New freezer. 15 days old. mildew smell in the
There is a curing process for the foam used to insulate these. It can give off a pungent odor until it is fully cured. Only experienced it a couple times in the last 20 years. eric
Jul 08, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Bosch Frost Free Frdge Freezer Icing Up
Switch off fridge. Put a pedistal fan in front blowing into the cabinet and leave until all ice has defrosted. Locate the drain hole in the back of the freezer compartment, try to defrost ice which blockes up about the first inch or two of this pipe. If water does not run through you need to force it through with a turkey baster. This should sort your problem. ratemeplease
Mar 12, 2009 | Freezers
Freezer
if the unit is a auto defrost sound like a defrosting problem, if not a self defrost and the coils are not covered in thick frost then a sealed system issue would be the problem to check
Apr 19, 2008 | Freezers
Frost in the freezer
IS IT ICE OR FROST? IF IT IS ICE, THE DOOR MAY HAVE BEEN LEFT CRACKED OPEN.
IF IT IS FROST, IS THIS A FROST FREE FREEZER?
IF YES, IS THE FROST ON THE BACK WALL?
IF YES, THERE IS A DEFROST FAILURE AND YOU WILL NEED TO TROUBLESHOOT THE DEFROST CIRCUIT.
IF THE FROST IS ON THE FOOD OR AROUND THE DOOR OPENING, A SEAL LEAK HAS ALLOWED WARM MOIST AIR INTO THE FREEZER AND CREATED THE FROST. CHECK THE DOOR SEAL FOR A GAP WHEN CLOSED.
Mar 24, 2008 | Freezers
Whirlpool 11.8 cu. ft. / 334 liter Upright Freezer EV120FXKQ Logo
361 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
