Most of the cameras with a date time clock have a secondary internal power source like a small watch type battery some point and shoot cameras use a storage cell which takes power from the main battery. This means when the main battery looses power the camera clock will hold a setting for about 1 day or 24 hours. To keep the camera clock set you need to keep a charge in the main battery. Here is a screen shot from the manual explaining this function.
Testimonial: "Thank you very much!"
Thank you for the quick answer, but Is thre a way to change that internal battery? Even with the main battery fully charged the date and time reset.
Sorry, it appears as if your camera uses a "storage cell" which is powered from the main battery the charge will only last about a day. There is no actual internal battery on this model to change.
So to me if you use the camera less often the main battery looses power and you need to charge then set the clock again. It appears as if this is the nature of the camera with lack of use.
