Question about Lexmark Office Equipment & Supplies
Error: "952 service NV failure". Lemxark C912 color printer.
5 Suggested Answers
  • 11 Answers
SOURCE: 994 Service Density Sensor Error
What the error means:
The 994 Density Error indicates that the printer's system card has encountered an unrecoverable error.
What to do:
This error normally requires a service call. However, on certain rare occasions, such as a power fluctuation or a stray static discharge in the vicinity of the printer, can cause a false 994 Density Error message to appear. In such cases, the error is only temporary and can be easily resolved without service. Follow the steps in the table to check.
Step Action
1 Power the printer off, wait ten seconds, and then power the printer back on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the page prints, the printer is functioning correctly.
2 If possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.
Yes: Continue to 'Contacting Lexmark' below.
Contacting Lexmark
When calling for service you will need to know your printer model type and serial number. If you need help locating this nformation, click here.
Call them while you're near the printer in case the technician asks you to perform a task involving the printer.
Posted on Jun 17, 2009
frcs68
  • 1605 Answers
SOURCE: Lexmark c912
980 error code is internal printer error. This is beyond users capability.
turn off the printer and check all cable connections.
turn on the printer, you need to call lexmark service, if the error return.
Posted on Nov 11, 2008
leroyal
  • 2120 Answers
SOURCE: We have a 5110 color
Search google....Lexmark Dell printer Minnesota
Posted on Jan 27, 2009
Patzky
  • 240 Answers
SOURCE: Printer flashes error "replace color cartridge"
Try unplugging the machine and removing all the ink cartridges.
Now plug the power back in. Wait a minute or two and then reinsert the ink cartridges.
If you get the same message, the machine's ink sensors are probably finished.
Thanks,
Pat
Posted on Nov 08, 2010
I have a lexmark c912. One day I noticed the colors weren't lining up properly. Shortly after that, there appeared a color distortion in the lower right corner. It was as if the magneta wasn't...
The proper color alignment is in the Config settings. This should only be done a certified tech. Can really screw things up bad if you don't know what you're doing. I am a Lexmark Tech.
Mar 02, 2017 | Lexmark C912 Led Printer
Canon MX328 Error code appear "5B00" what does it mean and how can i fix that error? thanks. jodans
not work, in display printer shows error 5b00. I can't go to nv ram setting. Can you help me?
Feb 08, 2011 | Canon Office Equipment & Supplies
994 service density sensor
The 994 Density Error indicates that the printer's system card has encountered an unrecoverable error. The 994 Density Error can be caused by the density sensor becoming dislodged from the sensor board. This normally requires a service call. However, for basic troubleshooting, try powering the printer off, wait ten seconds, and then power the printer back on. If still no go, if possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages. If problem persists, I strongly recommend contacting your Authorized Service Provider or Lexmark Technical Support for assistance. I hope I can assist you more on this.
May 10, 2010 | Lexmark C912 Led Printer
Lexmark C912 not reporting toner properly
print the status page make sure the revision level in the lower right corner is greater than 803.04 if its not go to lexmark to update the code if it is greater than. press the right arrow until reset toner Lvl appears in the display press select. use the right arrow to scroll through the colors to be reset. when you get tot the color you want to reset hit select it should give a brief message resseting toner then move to the next one. when finished you will need to power the machine down and back on again before the changes will take effect.
Nov 20, 2009 | Lexmark C912 Led Printer
994 Service Density Sensor Error Lexmark C912 Color Laserjet
What to do:
Step Action
Contacting Lexmark
Jun 15, 2009 | Lexmark C912 Led Printer
Lexmark C912 LED Printer
replace the rip baord if the firmware download failed ie flashing firmware eprom has fialed
Sep 29, 2008 | Lexmark C912 Led Printer
Lexmark c912
Jun 24, 2008 | Lexmark C912 Led Printer
C912 horizontal lines in print
change your magenta led it sounds like that may be faulty big job if not theat then its a new rip baord which is under the cover
Mar 12, 2008 | Lexmark C912 Led Printer
"981 Service Switch Error" and "994 Servise Density Sensor"
these are internal error. beyond user capability or repair
turn off the printer and check all of the cable connections.
turn on the printer, you need to call lexmark service, if the error returns.
Feb 17, 2008 | Lexmark C912 Led Printer
3,088 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
