Question about Gateway FPD2275W LCD Monitor
Desk top computer crt monitor
Brightness and contrast controls not responding.screen remains dark can see with difficulty even after powred up for an hr.
  • 3,940 Answers
Time to buy a new monitor, especially if you are still running a CRT monitor.
There is nothing you can do without taking the monitor to a repair shop, and that would cost more than the value of the monitor.
Posted on Jul 10, 2008
Adjusting brightness and contrast just went down and the screen remains dark. Setting up does not work. The monitor had a period of 2 years inactive; the fault occurred when I restarted into operation.
Replace it by a 15" or 17" LCD monitor -- these monitors can be purchased "used" for $20 to $50.
Or, spend $40 to $80 at a TV/video repair-store, trying to fix it. Your money, right?
Dec 11, 2010 | Daewoo 431X (White) 14 in.CRT Conventional...
Tip
How to save power even you are still using old VGA Monitor
Older monitors(CRT type) are using complex circuit than LCD, It requires more power consumption than LCD, but you can still save power by 30% through this tip.
1.You must position or install your monitor in a dark area or position.
2.Adjust the brightness control to the level of the black part of the picture must be seen black not gray, or became white.
3. Adjust the contrast control at your most comfortable level.
4.Avoid using bright picture screen saver or blank screen saver.
5.Turn off your monitor manually if necessary.
on Jan 19, 2010 | Computers & Internet
Monitor screen too dark. Some things aren't even visible
Adjust your monitor Brightness and Contrast and make sure you set it high enough to be able to view text and images. Refer to the monitor manual.
Nov 15, 2009 | Likom Futura LD7 17" CRT Monitor
Dark colors
Increege LOT screen preset
check G2 voltage at neck board G2 cathode
remove Sg caps
replace G2 pf
Oct 26, 2008 | LG Studioworks 700S 17" CRT Monitor
Brightness of picture
If you feel good about opening your set then you can try this: Look for the flyback (high voltage) transformer, with the thick red wire which goes to the top of the picture tube. There are 2 controls on the flyback transformer, focus (top) and screen (bottom)Turn the brightness and contrast all the way down and then increase the screen control until you see retrace lines, and then back it down until those lines just vanish. Return the brightness and contrast to normal and adjust the focus control, if necessary, for a nice sharp picture. Let me know if that brings your brightness back.
Aug 21, 2007 | JVC AV-27D104 27" TV
Dark image
Flyback transformers usually have 2 adjustable rods - 1 is for focus the other is for screen (G2) voltage. try turning Clockwise the Screen adjust with brightness-contrast at max. Till you see white diagonal lines, then go back until the lines disappear - then tune the brightness to your desired level.
Apr 27, 2007 | LG Flatron Ez T710BH 17" CRT Monitor
Getting More Brightness/Contrast ?
problem with my monitor Viewsonic E70....Memory recall keep flashing......any help out there.....
Mar 15, 2006 | HP 90 19 in.CRT Conventional Monitor
Gateway FPD2275W LCD Monitor Logo
57 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
