Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
What's the problem.
My television set when turn on sometimes automatically shut off, if not automatically shut off the display picture slow to appear. Can you help me find the solution? Jess Pinoy
  • 40 Answers
Hello... i will try to help you.this seems to be a power suply malfunction.make some measurements of the tension between groud and secondary tensions of the power suply(one or more of them could be lower),possible cause :one or more electrolytic capacitors damaged
Posted on Jul 10, 2008
I have a Sony kdf-e50a10 hdtvv that keeps shutting off every 5-6 min. And the picture appears dark.
It may be the lamp which sometimes will dim way down just before it fails-set monitors it and if too dim shuts down.
May 20, 2012 | Sony Televison & Video
Picture too large for screen after 2 months of normal operation
Have you unplugged your tv for 1 hour and restart it mostly problem will be solved or gently tap on the sides of the tv to get out of the zoom like mode .
How old is your tv ?
Did you replace any component in your tv recently ?
SAM ANDERSON
Sep 25, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
I just need to adjust the resolution on this TV. NO ONE at RCA could seem to help me. Thank you.
hi,
did u mean to adjust the picture setting then go for the following
1 press menu on the remote
2. using down arrow select picture quality and press ok. available options in picture quality and its use is listed below. you can use it according to your preference.
Basic Picture Control- Displays the five slider controls for adjusting
the way the picture looks.
Contrast Adjusts the difference between the light and dark areas
of the picture.
Color Adjusts- the richness of the color
Tint Adjusts the balance between the red and green levels
Black Level Adjusts the brightness of the picture
Sharpness Adjusts the crispness of edges in the picture.
When exiting this menu, the Save Personal Picture Preset choice list will
appear. You can choose either Yes or No. If you save the settings as a
Personal Picture Preset, the TV will store the settings so you can reselect
them easily if someone changes the settings.
Picture Presets Displays- a choice list that lets you select one of three
preset picture settings: Bright Lighting, Normal Lighting, Soft Lighting
or Personal Picture Preset. Choose the setting that is best for your
viewing environment.
Auto Color Displays- a choice list that lets you turn on the feature that
automatically corrects the color of the picture. (This is especially useful
for tracking realistic flesh tone colors as you switch from channel to
channel.) Choose On or Off, depending on your preference.
Color Warmth Displays- a choice list that lets you set one of three
automatic color adjustments: Cool for a more blue palette of picture
colors; Normal; and Warm for a more red palette of picture colors. The
warm setting corresponds to the National Television Standards
Committee (NTSC) standard of 6500?K.
Video Noise Reduction Displays- a choice list that lets you turn on the
feature that automatically reduces noise from the picture. Audiovariable
enables the TV to automatically adjust noise reduction level;
off turns off noise reduction feature; on-fixed sets a fixed level of noise
reduction.
Dec 21, 2010 | RCA G36705 36" TV
TV displays RGB code and then displays, no signal and then shuts off. What does the RGB code mean?
It means the source is not set correctly. Switch the source to input 0 (cable or antenna depending on your particular set up).
http://www.vizio.com/l32hdtv10a.html#support
Will lead you to the manual and quick start information if you need more specific instruction.
Joe
Jan 03, 2010 | Vizio L32 32 in. LCD HDTV
How do I start the cooker on low?
The manual says "When your corningware slow cooker is initially plugged into a wall outlet, the display will show"0". This display indicates the programmed number of hours for which a meal will cook.
The slow cooker can be programmed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears.
If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on HIGH setting. If 7,8,9 or 10 hours are selected, then the slow cooker will operate on the low setting.
To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
When the full cooking cycle is complete, your corningware slow cooker will automatically switch to the warm setting, to keep food at a warm serving temperature."
If, after you plug the slow cooker into the outlet, the COOK TIME button does not work, unplug the cooker, hold both ON/OFF and COOK TIME buttons down, plug into wall socket and wait till the display flashes. Release both buttons and the slow cooker buttons should both work.
Dec 18, 2009 | CorningWare SC60 Slow Cooker
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Hitachi 50ex20b shuts of
Hi, you need to stop running the set , call a tech and have him do some solder re-work, this is a cheap, easy fix, keep running it that way and it will become an expensive fix, gl, video-tek
Jun 06, 2009 | Hitachi 50EX20B 50" Rear Projection...
30" ASTAR LCD
Please call me 323-767-6030 and I will go through with you.
Oct 01, 2008 | Astar LTV-3001 Television
Black square on one channel
that's a picture inside a picture option, and it sounds like the inside picture is set for a blank channel...just go to the menu, and shut off the picture in a picture option..should do the trick..
and keep the kids away from the machine
May 24, 2008 | Insignia IS-LCDTV32 32 in. Television
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
97 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
