We have a Canon Imagerunner 1630 copier and it is showing Systom Error E000. How can this be fixed?
    Sniper:
  • 57 Answers
It is fixing unit error. Try to release error and if when switched back on it happens again, there is something wrong with your fuser.../heater.
Posted on Jul 10, 2008
I have imagerunner 1630 has code e000 how can i fix it
If the machine detects an error in the fixing assembly, the DC controller PCB operates
as follows:
[1] It causes the FSRDRV* signal to go '1' to cut power to the fixing heater.
[2] It causes the RLYDRV signal to go '0' to turn off RL1, and indicates 'E000' through
'E004' on the LCD in the control panel.
When 'E000' through 'E004' is indicated, the NVRAM on the DC controller
PCB remembers an error in the fixing assembly even when the
power switch is turned off and then on. After turning on the power, be
sure to execute the following in service mode to remove the error information:
#7 PRINTER > #4 PRINTER RESET > YES = (*).
sonsunny
Jul 06, 2011 | Canon imageRUNNER 1630 Copier
Error000
This error means that the Fixing heater is not working. It has not reached operating temperature after a specified time. It has probably blown the heater element.
You will need a trained technician to repair this.
E000 errors will not clear until the fault has been rectified and then reset by a technician. This is to prevent any fire risk.
Apr 30, 2010 | Canon Image Runner 1630 Copier Copier
Error code E000
can u please check the fixing
Aug 03, 2009 | Canon imageRUNNER 2270 Copier
E000 error message on canon imagerunner 2000 copier
Hello.
E000 means :
"The main thermistor reading does not reach 40oC 14 sec after the fixing heater goes ON (fixing low temperature error)"
Jan 19, 2009 | Canon ImageRunner 1600 Copier
My canon printer is showing system error E000
What they are talking about is to reset the printer. You should be able to do that by pressing the #7 and then the printer reset button.
Jan 14, 2009 | Canon imageRUNNER 1310 Printer
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
How to get in service mode on Canon ImageRunner 1630
You DO NOT WANT TO RESET THIS ERROR CODE !!!!!!!
there is a problem with the fuser, if you reset it most likely it will melt the rollers in the machine.
check the lamp (burn out), and thermofuse. replace
Oct 15, 2008 | Canon imageRUNNER 1630 Copier
Getting a eooo mesage
E000 error is due power surge or electrical fault within the copier. you can clear the error in service mode.
Sep 30, 2008 | Canon imageRUNNER 1630 Copier
E000
e000 is fuser temperature too low could be disconnected or the over heat senser has to be replaced and this code must be reset in service mode to allow copier to function.
May 12, 2008 | Canon imageRUNNER 1630 Copier
70 people viewed this question
k24674
jasbo
jasbo
