Everstar MPK 10crair conditioner
Internal container and external drain operation at same time. I per fer not to have to empty the internal. This just started happening this week after 3 yrs. I can blow through the drain hose, there seems to be no obstruction.
  • 39 Answers
Take off the little door off the back that holds the cord in place on the back. Now...peek to the side and you will see that the back hose connects to the little tiny tray. If you run weed eater line into the back hole and then up that little drip hole...the water will flow again.
Posted on Aug 21, 2010
Everstar MPK-10CR compressor keeps running after power off, on remote. Display blanks. Only shuts off when O/L @ wall plug tripped.
call in an electrician as there is a problem in the circuit allowing power from a neutral line and bypassing the switch
Jun 30, 2016 | Everstar Portable Air Conditioner MPK-10CR
It was flashing red like the water was full. I emptied the water, put the container back in and it was still flashing. I tried to shut it off, but it wouldn't shut down.
When you unplugged it you broken the circuit which is what it does when pan is full of water to get you by turn the two wires together to make it think the switch is made
May 31, 2016 | Everstar Portable Air Conditioner MPK-10CR
My unit displays P2 mode flashes red wont turn.....
P2 error indicates that the spill reservoir in the base of the unit is full.
Solution:
Move the unit to a location that is suitable for draining water from the unit. Remove the plug in the lower center of the back of the unit and allow the water to completely drain (Remember to replace plug.)
Remember...this is not the water tank on the side. This is the water than can collect in the bottom of the unit. Take it outside and drain it
Aug 20, 2009 | Heating & Cooling
No water in bucket when AC tells me its full
remove the drain bucket and look inside. there should be a hose that runs from the evaperator to the drain bucket. if you can blow air through hose to see if it is clogged. or try to take casing off and pour a little bleach/water mixture down tube , it probably has some mold built up in it
Aug 18, 2009 | Danby DPAC8020 Air Conditioner
Everstar Model MPK-10CR, What does flashing P2 mean?
p2 means the bottom pan is full, you need to drain the bottom, small valve on the back bottom in the middle
Aug 13, 2009 | Danby DPAC8020 Air Conditioner
What is the P1 error code on an Everstar portable A/C unit?
U need to empty the internal bucket, its full of water.
I have this air conditioner. What I did was get a long plastic tube from home depot and connect it to the middle back drain. I then put the plastic tube outside my window, or if u have a drain somewhere put it in there or put the end into a big bucket. Let gravity do its job. I did not connect the tube to the internal bucket b/c I would have to empty it too often. The air conditioner is on top of a table so that water will flow down the tube and out the window.
May 09, 2009 | Danby DPAC8020 Air Conditioner
Water going into carpet instead of ac water bucket
May 07, 2009 | Heating & Cooling
Heating & Cooling Logo
66 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
