Question about Dayton (1UM44) Fan
Replacing fan switchwith jin you e70469 switch, fan does not go to slow speed , juust hi, med, med off
Chain on a JInyou E70469 3 speed fan switch broke. need to replace switch
I have this exact Jin-You E70469 switch. Forget a replacement unless you drop about $20 on ebay. Westinghouse replacement switches did *not* work for this type of switch. Here's the solution that worked for me: CUT THE POWER and test before you touch anything electrical. 1) Diagram the wiring configuration of the switch noting where things go---take pictures. 2) Take out the wires that connect to it. Use a paper clip to spread the clips to pop them out. If you have any wires that come out and back in the switch itself, you can leave them attached. 3) See those pins that keep the housing together? Get a drill bit---or Dremel tool---just slightly bigger than the bottom of the pins. You're going to drill off bottom/rolled over part of those pins. Take it easy. LEAVE THE PINS IN. Do not take the pins out. With the bottoms of the pins ground off gone, now take off the nut that's threaded onto where the chain comes out. Now, carefully pry apart the bottom of the housing. Take a picture. Notice the position. Notice the position. Now, pry the little closure carefully just a little and replace the chain. Put the spring back exactly how it was. NOTICE the little finger in the bottom cover where the spring catches to snap it back. Put the bottom housing on. Holding the whole thing together, try the switch. If it doesn't recoil, pry it apart again, and adjust where the spring catches. This part will annoy some of you. Test again. If it pull ans recoils, you've got it. Put the nut on. Put electricians tape around the housing---don't cover any inputs. Re-insert your wires according to what you had. Put back together.
Mar 22, 2013 | Westinghouse Electric Westinghouse...
Need a santa e70469 switch
Pull Chain on Bottom
L 1 2 3
Upper Yellow Jumper Pink Grey
Lower Orange - Jumper Black
Santa E70469
SwitchCo part # 01
or
KensElectronics.com part # ZE-208D-01
z
Apr 23, 2012 | Hunter Dryers
Do you know of a way to slow down the LOW speed fan setting on a Kelvinator KSE70HRA air conditioner? Low is very noisy and blows air like a HIGH setting.
Hi, no, im sorry if it is on low already, it can't be changed to go any lower. The only thing I can come up with is the fan motored is wired wrong, and they have the high or med lead connected to the low speed, as it should run slow. On a central air system, there is a board that is in the indoor unit that shows the fan speeds, and they can be changed.I didnt look up your unit, and if it is a central air and not a window unit, you can change the speeds at the board. The wires are colored, blue is normally low, red is Hi, and blk or yellow is med. If this is a window unit, there is nothing much you can do. If you know anything about electrical, and you have a 3 speed fan, pull the cover to get to the switch back, and see what leads the have terminated to the switch. They may have it miswired. I wish you the best of luck,
Shastalaker7
A/C, Contractor
Jun 12, 2011 | Heating & Cooling
My fan motor runs to slow and needs to be speeded up. The fan motor has been changed to a A O Smith. Air conditioner is a Goodman 3 ton.
AO Smith motor speeds are Red low Blue med. And black high. Just unplug from fan switch plug in new speed. Turn power of first. Rus
Jun 17, 2009 | Goodman Heating & Cooling
Need to replace the switch that has ,hi,low,med off on nit? please Help
you have 3 control wires (the 3 speeds) and a common wire. the common wire will go directly from the fan motor to the power source/cord and the other 3 leads will run through the switch. you could even use a standard dimmer-style lighting rheostat and connect it to the common and "high" fan speed wire and have infinitely variable fan speeds. hope that helps.
Apr 30, 2009 | Lakewood HV-18 Floor / Box Fan
HI speed on my Hampton Bay ceiling Fan.
If you are looking to lower your fan speed, I suggest getting an adjustable wall switch that will limit the current to the settings. I have the same situation, I myself didn't do it but I know it is possible. In my bedroom, I have my ceiling fan wired to a turn knob switch, a dimmer so to speak, that limits the elctrical current, thus slowing the rpm's of the fan blades.
Feb 25, 2008 | Dryers
Dayton (1UM44) Fan Logo
1,867 people viewed this question
Top Dayton Dryers Experts
Jay Finke
Jay Finke
AZBen
AZBen
Piyal Perera
Piyal Perera
Are you a Dayton Dryer Expert? Answer questions, earn points and help others
