Question about Intertherm Heating & Cooling
I have an intertherm compressor. The thing has recently taken to melting the wires at the compressor(red wire and now yellow wire). If the attach lug on the compressor is burned down to the nub, is there an affordable repair other than replacement of the compressor?
  • 828 Answers
Replace the compressor and the wire harness that supplies the power to the compressor. Burnt off wires are due to bad conduction at the connections.
Posted on Jul 10, 2008
  • James Helmer
    James Helmer Jul 15, 2008
    Maybe a better answer to this asker would be a just plain NO.
Can you send me a diagram of the wiring for the tobishi DVD 7501
Hi David
Thanks but i don't have a lug for the speaker and the strange thing is that it has 4 wires , 1 red , 1 yellow, 1 blue and 1 green.
It also has another black input lug that looks like a shuttle control lug. I need to know how to get the sound out. the deck works perfect .
Sep 24, 2015 | Cars & Trucks
Can anybody tell me how the four wires hook up on glow plug relay. I have a hot a red wire with yellow stripe ,red wire and two brown wires. On 95 7.3 powerstroke
You have 4 wires, you have 4 lugs on the relay. It doesn't matter how they go on, except you have 2 big lugs and 2 small ones. Attaches the wires according to size, which side they go on doesn't matter. If you only have 1 small wire, it goes on the side marked "I" Ignition.
Apr 05, 2015 | Cars & Trucks
A/c compressor keeps blowing fuse
Disconnect The AC compressor clutch, does the fuse still blow.
Oct 21, 2012 | Cars & Trucks
New plug changed from a 4 wire to a 3wire,won't run.
You have 3 lugs to hook up to. right lug gets red or black, left lug gets red or black. Center lug gets white. you can also hook green wire to center with white. Or hook green to the screw for the lug cover. What you did is correct.
Jun 14, 2010 | Frigidaire GLEQ332A Electric Dryer
Weed eater pulled out red & white wires from thermostat at a/c unit. Red went to yellow and white to ?. Unit is an intertherm unit, model unknown but schematic #703909b
if there is only two wires at the condenser it does not matter which side of the contactor you attach it to with little blue wire nuts.
The two wires will send the required 24VAC to pull in the contactor
May 07, 2009 | Heating & Cooling
look on indoor unit to see what they used if only ac unit then only 2 wires needed common usually blue or black and yellow if heat pump then orange for rev valve o term on stat r red y yellow then white or brown for call for elect heat in defrost and blue or black for common also take some 3/8 clear tube to incase the stat wire and zip tie it to top of line set to help stop this
May 07, 2009 | Intertherm P3RA-030K Air Conditioner
White will usually go to white or blue, you can go to your furnace to verify which wire is connect to the common terminal (c)
Three wires melted.....
Possibly....usually a melted wire indicates a bad connection. Can you solder or crimp the wires to the compressor?
May 01, 2009 | Intertherm Heating & Cooling
Have a 620765 capacitor for my Intertherm ac outside unit. There are three connections on the capacitor. 1. Fan 2. Herm 3. C I have a yellow and red wire coming from the compressor. There is an orange wire...
pls connect capacitor terminal as folow
fan = connect wire come from fan
C = common -connect 1 wire from power
- connect1 to compressor term R
-connect 1 wire go to fan
herm =connect wire go to compressor term S
May 01, 2009 | Intertherm P3RC-048K Air Conditioner
Heating & Cooling Logo
204 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
