Question about Apple iPod nano
Ipod nano ipod will not turn off
  • 38 Answers
Best thing to do is to reset the ipod
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Posted on Jul 20, 2008
Mp3 Ver: ld 3088 - std 1.1 does not recognized! help!
There are several reasons why your iPod Nano may not turn on or awake out of its "Sleep Mode." This can be extremely irritating if you wish to use your iPod Nano, but the device is constantly malfunctioning. You may not need to take your iPod Nano in to be repaired if the player doesn't turn on as normal. There are a variety of different fixes that you can attempt as a way to get the Nano to turn on.
Flip the iPod Nano's "Hold" switch to "OFF." The iPod Nano cannot be turn on if the switch is set to "ON." Reset the iPod Nano. Move the "Hold" switch to "ON" and then "OFF." Then, press down the "Select" and "Menu" buttons on the Nano. Hold those buttons for about eight seconds. The Apple logo will then become visible on the iPod Nano. Once this occurs, try turning the iPod Nano on once again. Connect the iPod Nano to an iPod charger or a computer that is turned on via the iPod Nano's USB cord. Charge the Nano for at least 30 minutes. Then, try to turn the Nano on. Update the iPod Nano's software. Connect the Nano to your computer via the player's USB cable. Open iTunes, and click the iPod Nano's name on the left part of iTunes. Click the "Summary" option at the top of iTunes. Then, click on the "Check for Updates" button that's positioned in the middle of iTunes. Follow the instructions that appear inside iTunes in order to install the updates on the Nano.
Feb 03, 2013 | Apple iPod nano 3rd Generation
Ipod wont turn on
Flip the iPod Nano's "Hold" switch to "OFF." The iPod Nano cannot be turn on if the switch is set to "ON." Reset the iPod Nano. Move the "Hold" switch to "ON" and then "OFF." Then, press down the "Select" and "Menu" buttons on the Nano. Hold those buttons for about eight seconds. The Apple logo will then become visible on the iPod Nano. Once this occurs, try turning the iPod Nano on once again. Connect the iPod Nano to an iPod charger or a computer that is turned on via the iPod Nano's USB cord. Charge the Nano for at least 30 minutes. Then, try to turn the Nano on. Update the iPod Nano's software. Connect the Nano to your computer via the player's USB cable. Open iTunes, and click the iPod Nano's name on the left part of iTunes. Click the "Summary" option at the top of iTunes. Then, click on the "Check for Updates" button that's positioned in the middle of iTunes. Follow the instructions that appear inside iTunes in order to install the updates on the Nano. Hope this helps.
Jan 22, 2013 | Apple iPod nano
What is wrong with my ipod ao 5th generation
hope this helps
Sep 23, 2012 | Audio Players & Recorders
How do I turn off my ipod
As far as I understand it the older nanos does not switch, when you have finished listening to your music you slide across the hold switch and this will put the nano into a deep sleep mode. For the newer nanos see this article http://ipod.about.com/od/introductiontotheipod/f/Cant-Turn-Off-My-Ipod-Nano.htm will explain how you can turn them off. Hope this helps.
Jan 31, 2012 | Apple iPod nano
Won't turn on
Is your iPod fully charged? Sometimes the batteries become so depleted of charge that an accessory charger won't turn it on.
-Try plugging it in to your computer or a wall charger for a while, time will vary but it may turn on.
-If it is not turning on your computer will never recognize it, thus you won't be able to do a restore with iTunes.
-Try a hard restart as well this could help you.
Sep 02, 2010 | Apple iPod nano 4th Generation
Change language to english
You have to reset your iPod. (Note: This is for the 3rd generation iPod Nano)
To reset iPod nano:
1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold the Menu and Center buttons for at least 6 seconds, until the Apple logo appears.
If iPod nano won’t turn on or respond
- Make sure the Hold switch isn’t set to HOLD.
- The iPod nano battery might need to be recharged. Connect iPod nano to your computer or to an Apple USB Power Adapter and let the battery recharge. Look for the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving a charge.
-Logan
Dec 22, 2008 | Apple iPod nano
Ipod security code
You can unlock your iPod nano in two ways:
â Enter the combination on iPod nano by using the Click Wheel to select the numbers
and pressing the Center button to confirm them. If you enter the wrong
combination, it flashes red. Try again.
â Connect iPod nano to the primary computer you use it with, and iPod nano
automatically unlocks.
Note: If you try these solutions and you still can’t unlock iPod nano, you can restore
iPod nano. See “Updating and Restoring iPod Software” on page 50 for more
information.
Jun 26, 2008 | Apple iPod nano
Hold switch is disabled
You need to run the Restore/Recovery Tool
Do the 5 R's:
These are for Nano, but they apply to all iPods:
Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with your iPod nano. If
one of the following doesn’t help, read on for solutions to specific problems.
â Reset your iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer and make sure you have the latest software updates
installed.
â Reinstall iPod and iTunes software from the latest versions on the web.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page whatever.
Jun 05, 2008 | Apple iPod nano
Ipod security code
There is only one way - and it will erase all your songs:
If you lock your iPod nano screen and can’t unlock it
Normally, if you can connect your iPod nano to the computer it is authorized to work
with, your iPod nano automatically unlocks. If the computer authorized to work with
your iPod nano is unavailable, you can connect iPod nano to another computer and
use iPod Updater to restore your iPod software. See the next section for more
information.
If you want to change the screen lock combination and you can’t remember the
current combination, you must restore the iPod software, and then set a new
combination.
You can use iPod Updater to update or restore your iPod software. Apple periodically
updates iPod software to improve performance or add features. It is recommended that
you update your iPod nano to use the latest software. You can also restore the software,
which puts iPod nano back in its original state.
â If you choose to update, the software is updated, but your settings and songs are not
affected.
â If you choose to restore, all data is erased from your iPod nano, including songs, files,
contacts, photos, calendar information, and any other data. All iPod nano settings are
restored to their original state.
To update or restore iPod nano with the latest software:
1 Go to www.apple.com/support/ipod and download the latest iPod Update. The update
has the latest software for all models of iPod.
2 Double-click the software installation file and follow the onscreen instructions to install
the iPod update.
3 Connect iPod nano to your computer and open iTunes. The iPod Updater application
opens.
If you’re using a Windows PC and the iPod Updater application doesn’t open
automatically, you can find the updater by choosing Start > All Programs > iPod.
4 Follow the onscreen instructions to update or restore iPod software.
If you use the iPod Updater application and it doesn’t recognize that iPod nano is
connected to your computer, reset iPod nano (see page 45).
If you want to restore iPod software and you don’t have an Internet connection, you
can use the iPod Updater application that was installed on your computer when you
installed the software from the iPod CD.
-Tha Mp3 Doctor
May 26, 2008 | Apple iPod nano
Ipod
If your iPod nano won’t turn on or respond
1) Make sure the Hold switch is off.
2) If that doesn’t work, connect iPod nano to your computer’s USB or FireWire port. Your
3) If that doesn’t work, your iPod nano might need to be reset.
a) Toggle the Hold switch on and off (set it to Hold, and then turn it off again).
b)Press and hold the Center and Menu buttons for at least 6 seconds, until the Apple logo appears.
4) If that doesn’t work, you might need to restore iPod nano software.
Mar 12, 2008 | Apple iPod nano
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
