Question about HP DeskJet 695c InkJet Printer
Hp 695c i hardly ever use the color ink in the printer. i know it is not out of ink. now the printer will not allow me to print because all the sudden it is saying "color ink is installed improperly". Why? I haven't used it? Do I have to spend money on more color ink even though I don't use it?
Try taking the cartridge out and putting it back in. sometimes this makes the printer think you have changed the cartridge and it works.
Posted on Feb 20, 2009
How can i check which ink are out
Your printer should have come with a disk. This disk would have installed the necessary program that runs printing jobs, as well as keeps track of the ink level. Locate this program on your computer (may be under All Programs, Accessories under the Start Menu).
If not, Go into the Control Panel: (see below)
Above, you see "Hardware and Sound"; and below that shows "View Devices and Printers. Click on this. It will then bring you into the below dialogue box, of which shows any and all printers currently installed and which are being used. (see below)
Once you have located your printer here - (name etc). Go into your Start Menu: In the Search Box at the bottom type "programs"; look for the words "show which programs are installed on your computer", should be the fourth in the list. Below is what the list will look like. Find your printer here to ensure it's installed.
Once you have determined it's installed, you need to locate the printer program in your file system. Once you retrieve this, click it to open it. The program should allow you to view the ink levels. With most printers, when ink is low it will automatically open a dialogue box showing the ink levels for each cartridge. If you're printer is not equipped with this feature, then the only way to know if any need changed is when printing a document, and any color is not present.
I apologize for such a long response, as I wanted you to know how to access these files. If you are printing, and all colors appear to be present, without fading, or "blotchy" spots, then your cartridges are still good. You should be able to do a print test (calibration or alignment test) to determine this as well.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert, Phone Support, Live Chat @ Fixya.com
Jun 27, 2011 | HP Officejet 6500 Wireless All-in-One...
The printer's black ink cartridge won't print without the Tri-color print cartridge
Most of the HP printers are designed to allow printing onlywhen all cartridges are installed and
have ink.
Install a new tri-color ink cartridge and printing will continue as usual.
My printer, which is HP, does the same thing as yours, until I replace the empty cartridge,
printing stops.
Feb 22, 2011 | HP DeskJet 3745 Printer
Hello. How do you clean the cartridge as it is a little dried up for printer HP PSC 1210 all in one printer?
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
The best solution for you is to buy some isopropyl alcohol from chemist, which is a great solvent for dried ink, and drop 8-10 drops into the ink nozzle, put it back in and try running a few prints then repeat the process. If it doesn't help, you will be better off buying new ink cartridges.
Jan 05, 2011 | HP PSC 1210 All-In-One InkJet Printer
One colour cartdridge is empty can i print black only
To print with black ink only, you have to go Print, on the window that shows up click on Preferences then select the Color tab and tick the check-box for Print in Greyscale.
But bear in mind that ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you print with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
Dec 23, 2010 | HP Photosmart D7160 InkJet Printer
Color in printed pictures is terrible! All HP
try going into your printers properties and look for a print quality tab. One of the tabs will allow you to change your print style on pictures. Or the HP software that came with the printer should allow you to modify the print quality.
Jul 06, 2010 | HP Photosmart 3210 Printer
Hp printer power light keeps blinking -- wont print any document
Turn both your printer and computer off then after a few minutes turn back on. This should cancel the print job.
May 28, 2010 | HP PSC 2410 All-In-One InkJet Printer
Printing wrong color
You must do a deep printer head cleaning on your unit, it could be clogged and dirty and that because it will not produce or print out a proper color.
Let me know here again.
Dec 11, 2009 | HP Photosmart 8150 InkJet Printer
Hp psc 1210xi- the black ink cartridge appears to be out- i have a good color cartridge-how do I get the error off of my printer and print with my color cartridge?
  1. Take out the black cartridge once you've determined that you are completely out of black ink. You'll have to rely on the dark hues from the color cartridge to print in black.
  2. Adjust the printer software settings. Once you take out the black cartridge, your printer's software will typically warn you that you are missing a cartridge. Follow the instructions for your printer to allow the printer to print without the black cartridge. Then set the printer to print in black and white, not color. This overrides the black cartridge and allows the printer to access the dark hues of the color cartridge.
  3. Print a test page to ensure that your printer now prints black using the color cartridge.
  4. Print your documents. Bear in mind that your documents may not appear as black as normal. Still, they should be dark enough to pass for black, depending on how much color ink you have and the strength grade of the ink.
Sep 29, 2009 | HP Office Equipment & Supplies
HP printer not printing true color all of a sudden.
Altho the cartridge is new, you may have used all of the ink of one color. Pictures take an enormous amount of ink to print and all three primary colors are used to create the hues and colors indicated on the picture. Try a new color cartridge and see if that works.
Mar 22, 2009 | HP Photosmart C3180 All-In-One InkJet...
How can I print Black only?
Hi
HP Inkjet printers work only if both the cartridges have ink unlike HP Laserjet printers.
If you want the printer to print only in black, Follow the steps
Start --->Control panel -- >Printers and faxes ---->Right click on the printer icon (HP c5100) select printing preferences.
Under printing prefences there u will see an option to print with black or print in gray scale.
Note:HP Inkjet printers like Photosmart C5180 will work only both the cartridges have ink.
Thanks
Riz
Jul 26, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP DeskJet 695c InkJet Printer Logo
99 people viewed this question
Ben Johnson
