Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Laars LJ 175 Hot Surface ignition Problem
My pool heater blows the two in-line fuses on the igniter when it tries to start heating. I have installed a new igniter and the same thing happens.
  • Anonymous Jul 23, 2008
    Hi Greg,
    I have the extact same 2 blown fuses in-line from the ignitor on my Jandy lite2 pool heater. I haven't tried a new ignitor yet....before I buy one I want to hear if you have figured out your problem?
  • 139 Answers
Sounds like a board problem.has it been working and this a sudden problem or is it a new heater that you are trying to put into operation?
Posted on Jul 22, 2009
Ignition lk out code wha can i do
you can reset main power to heater however u will still have same problem. prob is from lack of gasflow, hot surface igniter failure, etc
Nov 19, 2013 | Teledyne Laars Laars Lite2 Heater 175000...
Laars lx won't ignite
hot surface igniter may not be hot enough to ignite the burners
Jan 09, 2013 | Teledyne Laars Laars Lx Pool Heater /...
Laars lj 400 heater has blown both inline fuses. Hot surface ignitor was replaced and new fuses installed. Both fuses burnt again. Safty curcuit was bypassed and fuses replaced again. BURNTagain! upon...
It is likely the voltage selector board, the smaller of the two, that is bad. In the past Jandy has recommended changing the heater over to 115V as a better option if you keep loosing the board(s). I forget their exact logic as to why but the last one of those I had behave like this was a few years ago and once we replaced all the burned up electronics and converted the power and the heater over to 115 it never failed again.
Perhaps Jandy would explain further if you need additional info, try calling:
1-800-822-7933
Sep 08, 2011 | Jandy Laars Lite2 Lj 250,000 Btu Heater
Why would the hot surface igniter burn out in two months?
It is very frail if you bump the heater hard while it is hot or cold you can crack it. If you have any water leak inside the heater or a condensation problem that drips water on it while it is hot this will break it every time.
May 07, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Jandy heater not starting
FL 4 is igniter failure.
1. check the fuses on igniter wire as well as the wires.
2. replace igniter
Jun 13, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
5 year old Laars 25,000 LX won't ignite.
The low pressure indicator is for the gas pressure not the water pressure. The heater won't ignite because it's not getting gas to the igniter. Check gas supply, if okay, check gas connections, valves, etc.
The 1 HP motor should be fine on the jacuzzi.
May 26, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Heating & Cooling Logo
75 people viewed this question
Top Lite On Heating & Cooling Experts
Paul Carew
Michael Galve
Michael Galve
Craig Butler
Craig Butler
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
