Question about Asko Dryers
There is a very strong, acrid smell coming from the dryer when it is in operation. It appears to be originating from the drum inside the machine. The lint traps have all been cleared and are cleaned regularly.
  • 13,433 Answers
Turn the dryer drum by hand it should have some resistance but not a lot.
does it smell like rubber?
the belt is made out of rubber and the belt overheating does make a plausible cause for the smell.
If its the belt you can replace it and that should solve it.
Posted on Jul 10, 2008
    Genius:
  • 3,422 Answers
Check the vent opening from the outside..
  • Priya darshan Jul 10, 2008
    Most likely the problem with your dryer is a clogged vent inside the
    wall. Also it could be crooked and smashed vent hose behind the dryer.
    It is pretty simple to make sure if there is a venting problem -
    disconnect the vent hose from the dryer and run a one load. If you'll
    see a difference - no doubt the vent needs cleaning.
    Good luck.
Strong gas odor only when oven is in operation?
If you're talking about the acrid smell immediately after starting the oven, that's aldehyde gas, a byproduct of cold gas combustion where the flame contacts the cold metal oven surfaces. That smell should disappear within the first minute or two, and it's entirely normal for a gas oven. If you're talking instead about the smell of fuel gas, then your burner may need to be adjusted; it may be running much too "rich".
Aug 23, 2014 | Electrolux Ovens
There's a slight burning smell coming from the dryer drum.
Some item may have gotten between the drum that rotates and the housing and during the rolling of the drum this item may be heating up from the friction. Check closely to see if you can find anything rubbing on the drum.
Jan 22, 2013 | Maytag PYE2300AY Electric Dryer
We have a frigidaire , Gas dryer. Our clothes come out with a hard, baked on greased colored substance, that you can kind of scrap of. There is a vent in the upper back, part of the blower sytem, that is...
Hi, If you don't clean out the lint trap frequently, your dryer may have small lint fires inside the cabinet. The smell from these fires can leave a strong odor in the clothes drum.
Here's what to do:
  • First, clean all of the lint from the inside cabinet and ductwork of your dryer.
  • Have a qualified appliance repair technician inspect the dryer for damage caused by any lint fire.
  • Move all containers of flammable liquids at least 50 feet away from the dryer. Gas dryers have a large flame when operating properly and can ignite the fumes of any flammable liquid or gas.
  • Then, try to clear the odor, by running a couple of loads of old rags or towels.
Apr 12, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
There is a strong oil smell in the dryer
If you have recently painted or varnished inside your home the fumes in the air can create a hydrocarbon type smell in your dryer. This should stop as soon as the house is aired out.
Oct 17, 2009 | Whirlpool LTE6234D Top Load Stacked...
Burning smell during drying cycle, coming from the inside back left grate. The grate appears discolored.
Usually when a gas dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat . If you don't clean out the lint trap frequently, your dryer may have small lint fires inside the cabinet. The smell from these fires can leave a strong odor in the clothes drum.
Also, if there are any solvents, paints, lacquers, etc. in use in the house, your dryer may alter and/or amplify the fumes to an odor unlike the natural fumes given by the solvent, paint, etc.
Here's what to do:
Jul 11, 2009 | Whirlpool WGD6200S Gas Dryer
WF740 Hotpoint washing machine with bad smell from drum. Tried 95 degree wash but still smells. Door seal slightly blackened but I think smell is from drum too. Any help?
Wash it out with a strong solution of washing soda placed into the drum before you fill the machine
Ps
Run the machine empty through a full hot cycle then run the soda one
The first will soften the deposits and the second should help kill the bacteria that is causing the smell.
Reducing the load so that there is more agitation helps as well
Jul 03, 2009 | Hotpoint Aquarius WD640 Front Load...
Burning smell and loose drum
If it is really noisey when it spins then this can only mean one thing.... the drum bearing are shot, its a complete strip down job, not an easy job for a beginer. Sorry
Dec 23, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
There is a strong, acrid smell coming from the dryer when in operation. It appears to be originating inside the drum as the clothes and inside of the machine have the strongest smell.
Odors that come from a dryer usually originate from a foreign source. Dryers move a large volume of air when in operation and can draw odors from long distances.Some examples are:
1. Foreign object left in a clothing item pocket.
2. Fresh paint, cleaning solvents, etc. used in other rooms
3. Wild animals entering through the exterior vent. (rare)
Investigate these ideas:
Check all pockets, cuffs,etc.
Has there been some redecorating going on the past few days/weeks?
Have you washed any rags containing cleaning solvents?
Is your lint filter damaged, chewed on,etc.?
You don't mention any abnormal noises in your complaint, but very rarely a mechanical/electrical anomaly could cause an odor, but only briefly as it would then have a tendency to malfunction,
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 10, 2008 | Asko Dryers
Dryer burning smell
Have you painted or stained in your house or apartment recently? The smell gets everywhere, dryer, stove, heating unit. I recently primed with Kilz and the clothes from my dryer smelled burned. When I called for service, it was the first question the service person asked and said they made a lot of useless trips only to find nothing wrong with the appliance. That was my case. I had to rewash clothes and let the dryer run with towels for a while
Jan 22, 2008 | Dryers
Dryers Logo
147 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
