In order to recharge the ac you first must clear the trouble code for the ac off warning. when you get this warning the computer shuts down the compressor to keep it from running without the lubricant that is in the freon. clear the trouble code and the compressor will run and you can recharge the ac.
If the compreessor dose not kick on when you put a can of 134 on it than you may have a simple ac relay bad ..or a clogged dryer or condenser...check with preesure gauges ....check connection on compressor too..it may be loose....make sure the ac is on high and comprressor ac button is press on...recheck disconnect high prresure switch if compreeseer ingages your right its a high prssure switch...but why is it going off ..check pressure ..to trouble shoot
If bring into a shop for repair what is a reasonable fee to fix this issue?
