Difrence of lan wan
Lan limit is 40 to 60km then 61km is wan
Difference between cat 5 ,cat5e , cat 6 cable
Posted on Aug 26, 2008
The Lan limit on unshielded twisted pair cable (UTP) is 300 ft for a local area network (lan). The cable uses the 802.3 Of course if fiber is used in a LAN then this # can be extended substantially.
Now the main difference between the LAN and Wide Area Network (WAN) is that LANs typically have 1 brodacast domain and froward packets at data link (layer 2 of the OSI) level using MAC addresses.
The WAN operates at the network level (layer 3 of the OSI). WANs are and reads IP addresses. Routers can extend far distances (as you said 40-60km) and band with depends on distance. the further away, the more attenuation on the line.
I hope this helps.
A wide area network
Posted on Jul 30, 2008
Can the management IP address of an ONT be configured?
ONT management IP addresses are classified as LAN-side management IP addresses and WAN-side IP addresses.
· The LAN-side management IP address can be configured. To do so, choose LAN > LAN Host Configuration from the main menu on the web page.
· The WAN-side management IP address is based on WAN port configurations.
§ If the WAN port statically obtains an IP address, the WAN-side management IP address can be configured. Ensure that the configured management IP address can communicate with the upper-layer device.
§ If the WAN port obtains an IP address in DHCP or PPPoE mode, the WAN-side management IP address can only be obtained from the DHCP server.
May 16, 2016 | Computers & Internet
Show Routing Table button will open a chart displaying how data is routed...
Show Routing Table button will open a chart displaying how data is routed through your LAN. Use the example below on how to configure a static routing:
ROUTER C ----------------- ROUTER B ----------------- ROUTER A--------------PUBLIC IP ADDRESS
ROUTER A: Gateway Mode ROUTER C: Router Mode
SM: 24 SM: 24
SM: 24 SM: 24
ROUTER B: Router Mode
SM: 24 SM: 24
HOP COUNT: 2 DNS: DNS of 1st router
SM: 24
1stRouter must be set on Gateway Mode
2ndRouter must be on Router Mode
Use Static Routing
Select Entry
Destination IP = IP Subnet of the 1st Router
Subnet Mask = Subnet Mask of the 1st Router
Default Gateway = Interface IP
Hop Count = 1 + n
Interface= Connection to the 1st Router
Hope this help everyone.
on Apr 22, 2010 | Computers & Internet
Cisco 861 behind Wimax Router from ISP
> ISP Router LAN IP: 111.222.333.174
> Cisco Router WAN IP: 111.222.333.175
Really? Each "octet" must be a value between 0 and 255, inclusive. A value such as '777' is not valid
Aug 27, 2012 | Cisco 861 Router
Can somebody help me with my problem on my router. I'm connected with the router but its only limited only no internet. I also try to connect it with LAN cable, i also got limited connection. what...
Because you can connect to the router by wifi and by cable it looks that the problem is NOT in the LAN or wifi part of the router settings.
The problem is located in the WAN part, that means the connection to your internet provider. The WAN settings must be made according to what your provider demands.
The most common settings are dynamic PPPoE connection type and of course user and password, but that can be different for your particular provider.
For example, if you have a cable modem, the WAN setting is usualy dynamic IP.
If it isn't enough for you to get the router connected to the internet, please post again with more details about your internet connection type and your provider.
Best regards,
Aug 29, 2011 | D-Link DSL-G604T Wireless Router
I'm trying to install a new 628 router. The wizard won't work and I have no clue what else to do. I have connected the router as per the limited instructions in the quick set up guide but it's not...
Connect your router to computer with ethernet cable then you can access it with following default link. or or or If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Dec 04, 2010 | D-Link Computers & Internet
I am trying to telnet through a Linksys RVS4000 from the wan side of the router to a fixed device on the lan side of the router. Both networks wan & lan are operational and I can ping the Wan side...
run netstat on the lan pc to see if telnet server is listening on port 23. look at logs on the router and pc to see if it is blocking any traffic. make sure lan pc has route back to wan
May 14, 2009 | Computers & Internet
Dax router
The 2 wire Home Portal 100w is a Modem/Router combination with wireless. But it has only one LAN port. So I understand that you are trying to use a DAX router for extending the number or ports. The reason they may not communicate if 2wire LAN is connected to DAX WAN is both may have same IP address. If the router has similar IP on WAN and LAN, it will not communicate. For that changing DAX router's LAN IP will be a solution or you can do LAN to LAN cascading. Connect 2Wire LAN to DAX LAN and dont use the WAN port. This way you dont have to change anything in the configuration
Dec 04, 2008 | 2wire HomePortal 100W (1000-400026-000)...
Cisco roter
All routers can route.
The commands are more than just a few for a proper link, but the simplest answer to the limited information you supply would be:
ip route <destination network> <destination subnet> <ip address of the remote router>
Do that on both ends, and you should be able to ping from LAN to LAN. I think that's what you want?
Nov 16, 2008 | Cisco 2524 Router
Dual Router Configuration
Plug the second router into the lan not the wan and it will act as a switch instead of a router
Oct 02, 2008 | D-Link DGL-4100 Router (DGL4100)
Siements 5890 router
When you say HQ is that outside on the wan port trying to ping the Lan port?
Sometimes the router itself will respond to a ping but will not pass ping requests thru as the internal firewall can never be fully shutoff unless you are running your cisco switch as a DMZ
also are you connecting your other pc's to the cisco or to the 5890.
Instead of shutting off the firewall completely try enabling bridge mode and give your cisco the outside IP addy.
Apr 30, 2008 | Computers & Internet
Computers & Internet Logo
240 people viewed this question
David Payne
David Payne
