Question about Panasonic DMC-FX07 Digital Camera
Stuck sd card
I have 9 sd cards (mostly 1g, 2 are 2g). I am constantly switching cards.
Yesterday one of my 2g cards got stuck! I can not use the cable to transfer my photos, it NEVER worked on my computer. (It did work on C.......Citys though) So I have to remove the card to transfer my photos.
How can I get the card out of my camera?
  • 3 Answers
Take battery pack out ... very very gently with a small screw driver inside battery port apply pressure to lower section of housing to sd card. should pop up when normal pressure is applyed to extract ... worked for me :)
Posted on Aug 04, 2008
My memory card won't lock in place therefore I get a "no memory" card message.
Unfortunately it sounds like the locking clip inside the SD card slot is broken or some how stuck? If you can try to look inside the SD card slot in the camera with a flash light, there should be a small clip like plastic to the left sticking out. That is what locks the SD card in place. See if anything is stuck in between like debris, you might gently poke that clip and see if it is stuck? That is what locks the SD card in place, if it is broken or missing, that will require some work to replace the plastic lock.
May 25, 2014 | Canon PowerShot SX10 IS Digital Camera
DSLR - Camera stuck in formatting mode
Hi!
if you want use the 4G you make sure your memory cards is compatible to 4G. then now you have got stuck when you back the 512!? all you have to do is to reformat your camera in to software. Thanks!!!
Nov 02, 2007 | Nikon D70 Digital Camera with 18-50mm Lens
Sd card stuck in acer a 510
Its your fault dude because you entered SD card from its back it will come back with the help of pin
Nov 11, 2012 | Acer Iconia Tab A510 Tablet
Hp photosmart 435 size of sd card
SD cards top out at 2GB, and any of them may be used with the camera. Any larger cards are SDHC cards and will not work.
Aug 22, 2012 | HP Cameras
Its stuck on macro mode and sd card is full
Those are two completely different issues.
There's a slide switch on the side of the camera, near the USB socket. Slide it away from the flower and toward the mountain to take it out of macro mode.
Transfer the pictures from the memory card to a computer or other storage device, then format the card in the camera to free up space.
May 21, 2010 | Vivitar ViviCam 8025 Digital Camera
I put one of those sd adapter cards in my pc's sd slot now it wont come out, my 1gb cards come out just fine but not this micro sd adapter card, IT'S STUCK
check if the lock and unlock switche is the one cozing the problem,it might be stuck some where/on somthing, inside the sd, cz mabe u pushed to hard when pluging it, or the sd is not compatable....
Jan 05, 2010 | SanDisk 2GB microSD Memory Card
My card won't let me take pictures or record video
Your camera supports an SD card. SD cards have a tiny switch that can be used to write-protect the card.
Make sure that the card memory is not full. If you are certain that the card is locked try to locate the tiny switch and move it to the 'unlock' position.
The following diagrams may assist you in finding the location of the switch:
Card Switch in Downward "Locked" Position (note the arrow by the word "Lock")
Card Switch in Up "Unlocked" Position
If you have tried this, and it is still showing locked, it is likely that the locking switch inside the camera's card slot is stuck. If you look inside the slot on the side of the slot where the SD card slide switch would be, you will see a glint of gold color on the side. This is the camera's lock/unlock switch. The other glints of gold that you may see at the far end of the slot are the reader's connectors (ignore those).
Camera's SD Card Lock/Unlock Switch
Somehow, the locking switch is making contact and has become stuck in the locked position (a single grain of sand can jam it there). With a plastic toothpick, or other skinny NON-METALLIC item, tap and gently push against this switch to see if you can jar open the contact to its normal unlocked position. Also try blowing compressed air at it, to clear out any gunk that may have worked its way in there, jamming it closed. Occasionally, reinsert the SD card to see if the issue has been corrected.
If repeated tries fail, it may be time to consider opening the camera to force open this switch (not recommended unless you have some familiarity with electronics).
Thank you for using fixya!
Oct 05, 2009 | Memorex Video Cameras
SD card locked for Samsung SL202
This used to happen occassionaly with my canon camers. Just use a peice of scotch tape or if you have one a small dab of hot glue to stop it from sliding.
Hope this helps FixYa,
Chris
Sep 03, 2009 | Canon PowerShot A560 Digital Camera
1G SD card "Cruical"
Make sure your SD card is really snugly inserted to the device. Also check your SD card compatibility list on the manual. Some SD cards have issues with electronic devices.
If the card is read on your computer, try reformatting it..
Dec 14, 2007 | Jazz DV-179 Digital Camera
Why is my *ist DS eating my SD cards?!
I've used Sandisk Ultra II 512M cards, a PQI 1G and a Transcend 1G card (all high speed rated) in the *istDS. I've done about 1500 exposures now, many RAW, and have done several rounds of upload to my computer. No problems at all. These same cards work flawlessly in a Panasonic FZ10 as well. Either you have had a bit of bad luck, two defective SD cards in a row, or have a *istDS with a stuck or bad memory card controller. Try using the Reset command in the Set Up Menu, see if that helps. BTW, always format SD cards with the camera once before you start using them.
Sep 13, 2005 | Pentax *ist DS Digital Camera
Panasonic DMC-FX07 Digital Camera Logo
146 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
