Question about Ricoh Aficio 450 Copier
N 450 aficio
I have a problem in my 450 copier it's give me a gray or soft copying ( the contrast is too bad ) when i make the ( 2207 ) from 107 program ( toner supply ) it's fixed. But it's return bad after 50 or 100 copying. i am changed the developer and the kind of toner and cheked the toner cycle. evrey thing is OK. but the broplem is still.can you help me.
Hi , how are you , how i can make the contrast is good in my aficio 450 copier
Posted on Aug 07, 2008
  • Ricoh Expert
  • 1,326 Answers
Have you replaced the opc drum lately?? The toner density is looked at on the drum with the ATDC sensor. It seems like your tring to adjust the toner density. That is just a band-aid. try to replace the developer and if needed the opc and clean the drum unit and the ATDC sensor. You shouldn't have to readjust in the service mode.
Posted on Jul 10, 2008
Ricoh Aficio 450... I want to alter copy delivery from internal to external tray.
press user tools option.
go to system settings.
go to out put copier
select the path you want
exit .
Jun 27, 2011 | Ricoh Aficio 450 Copier
RICOH Aficio copier is giving error code SC320, what is the problem?
i have a ricoh aficio 450 copier.it pick the paper from the tray and after afew seconds the paper will come without coping.(plain paper)
Jun 14, 2010 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 back side is dirty?
Problem on charge roller,Upper drum unite,please clean or change it then solve your problem.
With the best luck.
Jan 20, 2010 | Ricoh Aficio 450 Copier
What is the defrance between aficho 450 & 2045
the aficio 2045 is new version of the aficio 450.
so on the 2045 if you have installed printer/scanner option you can scan directly to folder on your computer or you can scan and sent documents to email addresses ,also the print or copy is much more quality.
you have a touch screen control panel.
mainly the look is the same with some new design on the look, but also some staff which has bean detected as problem on the aficio 350 now are corrected and improved.
Dec 13, 2009 | Ricoh Aficio 450 Copier
Problems copying with my Xerox 2515 copier
Paper goes on the bottom first. original goes in top next
Jul 31, 2009 | Ricoh Aficio 450 Copier
Soft
go to
driver.com
Aug 21, 2008 | Ricoh Aficio 450 Copier
Developer....
When developer goes bad you use more toner for one thing, but the main sign is a gray background in your copy. The print should be black but appears to be gray. The ricoh 350/450 was always noted to leak toner and developer as it runs. Check your machine and see if you see any small piles of toner, which also has developer in it, in the machine. Ther are small seals made of felt that need to be replaced if you have this problem. These seals rub against the drum sides....Good luck.
Jul 20, 2008 | Ricoh Aficio 450 Copier
Ricoh aficio 450
hi im jules_09,the average copy life as we call it is 60,000 copies after that you will replace the drum,cleaning blade and the developer.see first if the copy meter is already above 60,000 copies then about the print i think it time for you to replace all that is mentioned
Oct 11, 2007 | Ricoh Aficio 450 Copier
Opc drum
average drum life is 1,20,000 copies .you may get more than that.use good quality spare and consumables(I will prefer the original Ricoh).Machine will not create much problems.
Sep 28, 2007 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
165 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
