Question about Lands Phones
I have a Wharfedale phone which has stopped working. On the screen it displays no signal, upon trying to reset it and change certain settings it states "unavailable". Any help?
I have a warfedale phone which will not connect to the base and dose not rin
Posted on Sep 02, 2008
No Signal After Restoring PC to Factory Settings
It's not recognizing the TV as a monitor. Find out what resolution the TV runs, then set the PC to those using the other monitor.
Apr 06, 2017 | Compaq Computers & Internet
Nokia N86 crazy screen colours.
Release in early 2009, I like the camera and the inbuilt memory of this phone. Firmware updates are always available and you certainly can try a software update. Nokia stopped N-gage for this phone now. If you really think its not a hardware (display) problem, and the update is not helpful, you can try to reset the phone to factory setting. The code is *#7780# for soft reset and *#7370# for hard reset. During reset it will ask for password, the default password is 12345.
Dec 02, 2011 | Cell Phones
Restore factory settings caod reset
THESE ARE THE CODES FOR NOKIA 6300
Choose the ones you want
On the main screen type in:
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin# \
*#7328748263373738# resets security code.
Default security code is 12345
Change closed caller group (settings >security settings>user groups) to 00000 and ure phone will sound the message tone when you are near a radar speed trap. Setting it to 500 will cause your phone 2 set off security alarms at shop exits, gr8 for practical jokes! (works with some of the Nokia phones.) Press and hold "0" on the main screen to open wap browser.
Let me know if it works
Regards
Tom
Dec 30, 2010 | Nokia 6300 Cellular Phone
Wharfedale Florence handsets restart on incoming call
We are having the same problem as you with our Wharfedale phone. Did you ever find a solution?
Thanks
Oct 29, 2009 | Lands Phones
Wharfedale IN120 wont stop beeping
i have a wharfedale in120 cordless phone i can ring out but can not get a ring tone in ..... i have tryed everything
May 22, 2009 | Lands Phones
Security code problem
Check this out.
Thanks.
Jan 05, 2009 | Nokia 1600 Cellular Phone
Input Signal Out Of Range
press F8 upon booting up instead of choosing safe mode click ENABLE VGA right click desktop, click properties, click settings, set resolution to 1024 x 768 from there you will not see anymore the Input Signal Out Of Range
Apr 11, 2008 | Akai LCT2060 Television
Wharfedale dvdrhd400 problems
Change the Scart setting (in the setup menu) from the default setting (RGB) to the other available setting (CVSC?).
I have a problem with my box restting the clock on a random basis, making it impossible to set a timer to record anything - let us know if you get the same problem via this site!
Jan 03, 2008 | Wharfedale DVD-M3 DVD Player
Error code
I had the same problem - turn off at the wall and on again fixed it.
Dec 07, 2007 | Wharfedale DVD-M3 DVD Player
Lands Phones Logo
135 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
