It ia an acer aspire 3004 laptop. The battery charging % remins at 74% all the time and when I remove the power the lap top turnsoff completely.
    Sergeant:
  • 264 Answers
Well it surely shows that the battery is not providing backup to the laptop. There could be few reasons for the same defective and faulty battery is one of them.
However i will give you a step which you should try once and see if it makes any difference.
Method (Power cycle)
You need to remove the battery, adapter and any other device connected to the computer (May be any additional cards or any wires as for Ethernet or speakers or external mouse/keyboard).
Nothing should be connected at all.
Now Press and hold the power button for 25 seconds (It wont show anything). This is a step to release any static charges developed, which may surely caused the kind of issue you are facing.
Now connect the battery and the adapter and check whether it is charging the battery and provides you the backup.
The usual battery life is said to be 1 year. if you are using an older battery, kindly get the same checked as well.
Hope his will help. Please let me know what happens.
Regards
Sammy
Posted on Jul 10, 2008
My acer aspire 4730Z is not turning ON....battery is down....when am connecting dh charger pin to dh lap, dh green indicator of dh charger goes on blinking. Lap top is like completely dead dat even dh...
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Replacement Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Intocircuit Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Nov 19, 2012 | Acer Computers & Internet
My aspire 5100 wont hold charge without charger
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 05, 2012 | Acer Aspire 5100 Notebook
Acer aspire 7551 Battery will not charge.
I had a similar problem with a laptop years ago...Where the battery terminals connect to the motherboard, and Im not sure about yours because the models are obviously way different, but in some, they use "battery boards" that connect to the motherboard and are seperate from the system. Those "battery boards" have lots of micro capacitors and resistors on them and are responsible for charging the battery and completing the power circuit to "start" the computer. If I took the battery board out of the laptop I had, the whole thing wouldn't work. Since your laptop is starting while plugged in, but the battery is not charging...I would look into this area first. I am going to rummage around to see if I can find a schematic of your laptop and maybe some parts info.
Jun 20, 2012 | Acer Aspire 7551-7422-22085
Acer 53338 lap top got power but won't turn on
Remove main battery and try again, next sub out the ram memory one at a time and power up each time. If still unsuccessfull the DC jack in the laptop is the most likely problem, they often develop bad connections at the DC plug source causing all kinds of symptoms, the computer must be dismantled down to the motherboard level to address this.
May 04, 2012 | Acer Aspire 7520-5185 Laptop
Acer aspire 3004 battery not charging
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Oct 02, 2011 | Acer Aspire 3004WLCi Notebook
I'm using a "ACER aspire
There should not be a problem provided the notebook is used with the battery on occasions and charged up again when the battery level drops to approx. 25% level.
Jun 15, 2011 | Acer Aspire 5742Z-4200 Notebook
Hello, I have an acer aspire 5741 which i bought 5 months back. The problem started a week back and has got worse. It is when i plug the cord for charging on laptop, the blue light on power button and...
it needs a new a\c power block inside they are cheap and semi difficult to repair i wouldnt think it would be over 100$ max but it isnt in my lap to inspect so this is my opinion ok
Dec 21, 2010 | Acer Aspire One PC Notebook
Laptop will only charge when switched off
get orignal charger for acer aspire 5735 pc and then try again
May 03, 2010 | Acer Aspire 5735 Notebook
My lap top wont turn on i have a blankj screen the
Please try these. After on your pwoer botton wait 2 minites and the press FN+F6.
Let me know what happening.
Thanks.
Jan 30, 2010 | Acer Aspire 6920 Notebook PC
My acer lap top key board is doesn't work
Try to turn off the acer laptop, remove the cables and battery . Press & Hold the power button. Then replug cables and battery. Turn on pc and if symptopm persist, consult acer tech support at 1-800-816-2237
Dec 14, 2009 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
