Question about C. Crane FRS AM/FM/SW Radio
No Sound I have a Sangean Platinum Edition CCRadio that I've owned for 6 years+. Has always been plugged in with the original power supply. The display comes up, tunes to channels but no sound. It has never been droped or smacked. Have tried reset . . . no worky. Rufkarma
Try plugging it the headphones in and out a few times,problem could be bad connection it that connector
Posted on Aug 01, 2009
2003 Pontiac Vibe - 4 Cyl. 150k miles. Ignition coils keep going bad - every 4-6k miles. Coil 1 has been replaced 4 times, Coil 3 once. Coil 4 twice in the past year (20k miles). All spark plugs
Install new spark plugs, 4 new coils & replace the oxygen sensors
O2 Sensors are only good for 100,000 miles, then slow
down or quite
No idea why the coils do not last 5 or 6 years
Cylinder #1 is always at the front on a 4 cyl
Go to Rock Auto --Buy Wells Coils,NGK Double
Platinum Plugs & NTK O2 Sensor
Those parts are expensive because you have a Totota
Motor I guess
Clean MAF Sensor with CRC MAF Sensor Cleaner
Jan 08, 2013 | 2003 Pontiac Vibe
My Telefunken 42" Full HD
The problem might be on your power supply.
1. Check the power supply it is located on where the plug is connected on the main board.
2. Use a multimeter it must be on AC function, to check the AC supply
sometimes the problem is just on the plug
3. Then if there is an AC supply on your plug then check the power supply
4. Check for busted fuse (usually has no reading on multimeter on diode test)
replace same type of fuse.
5. If the fuse are good check for open resistor or shorted transistors.
always replace same rating of resistor and transistors (same on number and type)
IF the problem still exist just contact me.
Hope this may help you..
Aug 20, 2011 | Televison & Video
Vegas movie studio hd platinum 10.0
Welcome to FixYa
Professional-Level Power for Your Home Studio. Vegas Movie Studio HD Platinum software has everything needed to produce spectacular HD movies. Edit video in nearly any format including HDV and AVCHD. Powerful features for video compositing, color correction, and soundtrack creation help you get feature-film results in your home studio. Use the surround sound mixing tools to create 5.1 soundtracks. Choose from hundreds of professional 2D and 3D video effects, titles, and filters. Upload movies to YouTube, burn to Blu-ray Disc, or author DVDs using beautifully designed themes or your own custom menus and graphics. Exclusive Sony Show Me How interactive tutorials help you get started fast. Vegas Movie Studio Platinum Edition - powerful tools for video compositing, color correction, and surround sound mixing help you get feature-film results in your home studio. To share, upload movies to YouTube, burn to Blu-ray Disc, or author DVDs with custom menus and graphics.
For More Click here
Thanks for Contacting FixYa
Jun 27, 2010 | Sony Vegas Movie Studio Platinum 9 for PC
Numark 360 21v 750ma Power Supply
Try the following sites
http://www.powerstream.com/power2.html
http://www.platinum-records.com/Numark-21V-750MA-AC-Adapter-Power-Supply-prod7509.htm
Or even a cheap replacement laptop power supply as these usually start at 1000 mA which will give you current to spare and have a longer lifetime. most of these cover from 15V to 24V and are either auto switching or manual select for the voltage. Plus you can pick these up from most electronic / big box / supermarket shelves
Aug 10, 2009 | Numark DM1200 DJ Mixer
Sangean ATS-803A - no audio
If its not a micro-p glitch, sounds like the radio was subject to a spike or surge wile plugged into the AC adapter. If the "power" light stays on all the time, thats what happened. Believe me, I was Sangean America's tech from 1990-1995.
Rob
The fix is to replace a transistor, or fet in the main pwr supply. (Close to where the adaptor plugs in.)
I wish I could give more details, but its been 14 long, long years.
Jun 03, 2009 | Sangean ATS 808A AM/FM/SW Radio
Creative Labs Sound Blaster Audigy 2 ZS Platinum
No, you cannot fix this. Any replacement you buy will work fine no matter where you are located. You may want to do a Froogle search from Google and shop by reseller rating and price.
It is the Power Supply for the PC that needs to be adaptible with your country's power grid. So, don't worry about that just be more careful, as I'm sure you will, when you install the power plug to your sound card.
Regards,
Worldvet
May 18, 2008 | Creative Labs Sound Blaster Audigy 2...
NO Sound - 865PE Neo2-PFS Platinum Edition
You need to install the correct version of the sound drivers from the MSI website under your motherboard type. Third party or from Realtek sound drivers won't make you sound chip works. If after installing sound drivers from MSI website still don't work then your on board sound chip colud be defective.
Jun 29, 2007 | Abit AS8 Motherboard
ATS 505 Power Supply Problem
Make sure no other buttons are held down when powering up, although you usually see a clock on the display if there is power but the unit is locked up for another reason. The fact that you've tried batteries and you've tried the PSU suggests to me that there is some other problem with the radio, it could be as simple as a dry joint, but without experiencing the same problem myself it's not possible to suggest anything further.
Sep 18, 2006 | Sangean ATS 505 AM/FM/SW Radio
SANGEAN ATS505
try the power switch a few times and more force than usual.
Sep 16, 2006 | Sangean ATS 505 AM/FM/SW Radio
C. Crane FRS AM/FM/SW Radio Logo
266 people viewed this question
Top C. Crane Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a C. Crane Audio Player and Recorder Expert? Answer questions, earn points and help others
