Omni tv remote control code - Televison & Video
  • milfords Nov 06, 2008
    Omni 80cm TV, model T8005NF - need remote code please as it's own remote is dead and I wish to link to an LG DVD/VCR remote. Please help!!
I have jVC tv and a omni universal re mote control what the codes for the tv.
0286,0288.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 24, 2014 | Televison & Video
JVC tv needs codes from omni remote control the model number OmnA12 AVO58
2509,2500,2507,2503.
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
What is the code for an omni 3208 ltv? controls on side of tv are not working, does anyone know how to overcome this problem?
Refer its user manual for details. Panel lock is ON now. Make it OFF. Instructions about this are there in the manual. Gopakumar Gopalan Google
May 21, 2014 | Televison & Video
Omni tv codes
082,089,085,083. Check these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given.
Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy
Oct 10, 2013 | RCA Universal Remote Control
Want to reset the v-chip on my 2001orion tv model # 1933
Omni TVs have a child lock that allows parents to prevent children from watching specific channels or television shows with certain ratings. To activate or deactivate the controls, you need the four digit pass code. If you forget the pass code or if the lock gets set accidentally, you can still unlock the TV.
• Use the original Omni remote control to turn on the TV. You need the original remote to bypass the child lock. A universal remote won't work.
Check the screen. If you see a blank screen with a red key on it, press the "Function" and "Mute" buttons at the same time. This unlocks only the channel that is on the TV. All the other channels will remain locked and the TV will lock again when it is turned off.
• Unlock all of the channels on the TV by entering "6688," which is the factory reset code. This code resets the TV to original factory settings. Once this is done, you will have to go through the initial setup.
• Call Omni technical support at (416) 260-0047. A technician can help you troubleshoot the television as the problem may not be the child lock. You'll need to know the model number and serial number of the TV.
•Take your television to a TV repair shop if you are still unable to unlock the TV. The problem may be with the wiring, so the repairman may have to rewire the TV
Aug 12, 2012 | Televison & Video
Lost remote for omni T8005NF model tv
Buy a universal remote control, which have setup codes for Omini TV.
Apr 14, 2012 | Televison & Video
TV Locked - Omni v6833nf
Use the original Omni remote to turn on the TV. press the "Function" and "Mute" buttons at the same time. Omni technical support: (416) 260-0047.
Mar 25, 2009 | Televison & Video
Hi i have a giant tv remote lost the code for the rca tv the remote is an Omni tech could you help
yes i can... the codes are 000,003,004,005,007,009,011,015,048,082,092,094,096,098,101,102,103,107,113,125,129,167,179,187,188,191,and 194. ok you first turn on the tv. then hold down on the code search button for 3 sec. or untill the led stays on. try each 3 digit code untill it works. some codes my turn off tv but wont change channels. try another code untill it all works for you....... hope this helps........ thanks eddy
Jan 02, 2009 | Brookstone 538744 Remote Control
Parental block problem
U NEED A MASTER CODE RING THE COMPANY THEY WILL BE ABLE TO HELP YOU- BUT THEY DO TAKE FOREVER
Jul 01, 2008 | Televison & Video
Televison & Video Logo
442 people viewed this question
Top Televison & Video Experts
Electro Med Services...
